Export Dashboard "extenally" via API
I went through the forum questions, this has been asked several times but haven’t found anyone responded. Example of one such request:
    10.x
    Export dashboards externally via API to import into another grafana instance
    using API calls
  • What happened?
    Haven’t found documentation related to exporting dashboard externally.
    No
    We can achieve this using Grafana UI but this isn’t ideal for scaling purpose. This is bad experience for operation limiting the scalable solutions
    No
No, there is no official API.
Is this time available in future roadmap ? if not is there way to request the feature. I have seen this has been requested by several folks for couple years now, was looking if a feature is already existing so we can track the availability.
I don’t know :person_shrugging:. Try to search in the Github repo issues/featue requests.
I am curious @sbatchu0108
Did you find any qwrkign solkutiont o export for External use.
Super important I think.
E
so if no official docu for this, then probably best to contribute to it?
but that said you can get the dashboard via api and then save it using a scripting language of your choice.
