Dashboard not showing data
Hello everybody,
i am a newbie learning Grafana and i am having some troubles setting up things from a tutorial. Any feedback will be welcome.
thanks and cheers,
David
Grafana: v7.5.5, Docker
Inlfluxdb: v1.8, Docker
Jmeter v5.4.1
I am trying to display JMeter metrics. Test plan is pushing data to InfluxDB using the HTTP API using the InfluxdbBackendListenerClient.
Al in all, i am following the linked resource, but under a dockerized setup. I can confirm that Datasource in Grafana is correct since i can get a success message when saving it in the admin UI.
Jmeter is also pushing data to influxdb since i can list the series using the influxdb http api.
Actually if i try to build a new fresh query by hand, i manage to display some data.
See linked resource at end
  • What happened?
After importing the dashboard (JMeter Load Test dashboard for Grafana | Grafana Labs) i can only see the Requests of my plan on the Request dropdown from Grafana Dashboard, but no data is shown.
It sounds to me some issue with the dashboard it is just i can not figure it out which.
Data is shown in panels on the dashboard
No errors.
Hi @davidmpaz
Looks like that dashboard hasn’t been updated in 4 years, so I’m not surprised that some of the panels are broken. Did you look at any of the queries for those broken panels? Perhaps copy them into explore and see if you can fiddle with them?
