Version 10.2.2 -
I have installed grafana from official grafana repository, and I am using PostgreSQL as grafana DB. I have installed influxdb as data source and using it.
What I am trying to achieve is accessing the dashboard from other computers with the same network.
What happened?
I can log in to Grafana but the dashboard is showing No data. I have checked other similar issues here but non of them fixed my issue. -
The dashboard should be shown like I can access it on my PC. I have already allowed port 3000 on my firewall and I am able to login actually the problem is only with dashboard. -
There is error logs in grafana.log, just access logs are there -
No I just followed grafana documentation.
