How to access grafana dashboards from another pc
Hello all,
How can i access my dashboards from another pc ? Both pc connected same wifi. I tried to make public my dashboards but not work. I just want to access from another pc via url adress
thanks for supports
use the same url you access on the one machine on the other machine, just make sure you use the ip of the grafana url, or that the hostname is accessible via dns. if it is not accessible, you might need to open the port on the firewall
