grafana 9.3.6 deployed via grafana operator
- What are you trying to achieve?
We have a set of dashboards that do not show up despite their being [supposedly] successfully installed
- How are you trying to achieve it?
We install two sets of dashboards, currently. One set get installed via configmap method and the other via directly to the CRD using CRs.
- What happened?
The dashboards show up as recognized/installed CRs but the dashboards do not show up in the grafana browser.
We expected the dashboards to show up in the browser. Manually importing JSON works fine. The CR installations do not.
- Can you copy/paste the configuration(s) that you are having problems with?
One sample:
apiVersion: integreatly.org/v1alpha1
kind: GrafanaDashboard
metadata:
annotations: {}
namespace: grafana
spec:
json: |-
{valid JSON here which I cannot show}
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
This is the problem. There are NO errors. There are no clues that I can find which help me understand what’s going wrong. Log level is set to debug.
- Did you follow any online instructions? If so, what is the URL?
No. Nothing outside the ordinary.
