Panels become invisible on every dashboard
Hello I got a problem with Grafana and after an hour of debug, changing version, trying to reimport dashboard I can’t figure it out. Please help me :smiling_face_with_tear:
Version 12.0.2 (dockerized)
Import dashboards from API
I got a Python code that generate grafana dashboard as json from presets.
Then I use the grafana API
  • What happened?
After using the API calls even if I got 200 anwsers it appeared that some parts of the panels become invisible. To be sure it is not my dashboard that is bugged I check this one that is imported from grafana.com : Node Exporter Full | Grafana Labs
The thing that is weird is that some panels are still working like this one
I expected the dashboard to be displayed properly
Here is my dockerfile to launch the service. It worked
for a while since I tested my code to generate a json that I imported manually via the front.
grafana:
    user: "${USER_UID}:${USER_GID}"
    container_name: grafana
    image: grafana/grafana:12.0.2
    networks:
      - monitoring
      - proxy
      - authelia
    volumes:
      - /srv/grafana/data:/var/lib/grafana
    environment:
      - GF_SECURITY_ADMIN_USER=$GRAFANA_USER
      - GF_SECURITY_ADMIN_PASSWORD=$GRAFANA_PASSWORD
      - GF_SERVER_ROOT_URL=https://grafana.domain.com
      - GF_SECURITY_ALLOW_EMBEDDING=true
    ports:
      - 3000:3000
    labels:
      - "traefik.enable=true"
      - "traefik.http.routers.grafana.rule=Host(`grafana.domain.com`)"
      - "traefik.http.routers.grafana.entrypoints=websecure"
      - "traefik.http.routers.grafana.tls=true"
      - "traefik.http.routers.grafana.tls.certresolver=myresolver"
      - "traefik.http.services.grafana.loadbalancer.server.port=3000"
      - "traefik.http.routers.grafana.middlewares=authelia@docker"
I recieved no sign of any error.
I used the grafana swagger presented by my grafana instance.
Welcome to forum @alexidesvignesnouvel
Are you basically trying to migrate your grafana?
Is the backend, sqlite or something else?
Hello, thank you for your response.
With no hope left in mind I tried the first rule of IT: rebooting…
It worked so it seems that the problems came from my navigator (Firefox)
It works perfectly now.
Thank you for your response and sorry for your time :slight_smile:
