I am running “Grafana 6.2.4” in my linux server.
I have exported a json file from my dashboard and saved it in the name of ‘test.json’
Now i deleted the already existing dashboard and try to upload the saved ‘test.json’ using curl http API
so i ran the below command,
curl -v -X POST --insecure -H "Authorization: Bearer
eyJrIjoiOWwwUmpQYUFmczhRVG1CZ1VmdTZ1VlZLTlcdd2b0xUb0QiLCJuIjoia2xhIiwiaWQiOjJ9" -
H "Content-Type: application/json;Accept:application/json" -d '{"dashboard":{"id": 35,"title":
"importTest","uid": "importjson","tags": [],"timezone": "browser","rows": [{}], "schemaVersion":
18,"version": 2},"overwrite":false}' --data-binary "$(/u04/rhsappnbb_metrics.json)"
http://localhost:3000/dashboards/import
For the above command the grafana API thrown the error like below,
- About to connect() to rhsappnb port 3000 (#0)
- Trying 10.x.x.x…
- Connected to rhsappnb (10.x.x.x) port 3000 (#0)
POST /dashboard/import HTTP/1.1
User-Agent: curl/7.29.0
Host: rhsappnb:3000
Accept: /
Authorization: Bearer eyJrIjoiOWwwUmpQYUFmczhRVG1CZ1VmdTZ1VlZLTlc2b0xUb0QiLCJuIjoia2xhIiwiaWQiOjJ9
Content-Length: 143
- upload completely sent off: 143 out of 143 bytes
< HTTP/1.1 404 Not Found
< Cache-Control: no-cache
< Content-Type: text/html; charset=UTF-8
< Expires: -1
< Pragma: no-cache
< Date: Tue, 09 Jul 2019 12:03:42 GMT
< Transfer-Encoding: chunked
Grafana
.preloader {
height: 100%;
flex-direction: column;
display: flex;
justify-content: center;
align-items: center;
.preloader__enter {
opacity: 0;
animation-name: preloader-fade-in;
animation-iteration-count: 1;
animation-duration: .9s;
animation-delay: 1.35s;
animation-fill-mode: forwards;
.preloader__bounce {
text-align: center;
animation-name: preloader-bounce;
animation-iteration-count: infinite;
.preloader__logo {
display: inline-block;
animation-name: preloader-squash;
width: 60px;
height: 60px;
background-repeat: no-repeat;
background-size: contain;
background-image: url("data:image/svg+xml,%3csvg version='1.1' id='Layer_1' xmlns='http://www.w3.org/2000/svg' xmlns:xlink='http://www.w3.org/1999/xlink' x='0px' y='0px' width='351px' height='365px' viewBox='0 0 351 365' style='enable-background:new 0 0 351 365%3b' xml:space='preserve'%3e %3cstyle type='text/css'%3e .st0%7bfill:url(%23SVGID_1_)%3b%7d %3c/style%3e %3cg id='Layer_1_1_'%3e %3c/g%3e %3clinearGradient id='SVGID_1_' gradientUnits='userSpaceOnUse' x1='175.5' y1='445.4948' x2='175.5' y2='114.0346'%3e %3cstop offset='0' style='stop-color:%23FFF100'/%3e %3cstop offset='1' style='stop-color:%23F05A28'/%3e %3c/linearGradient%3e %3cpath class='st0' d='M342%2c161.2c-0.6-6.1-1.6-13.1-3.6-20.9c-2-7.7-5-16.2-9.4-25c-4.4-8.8-10.1-17.9-17.5-26.8 c-2.9-3.5-6.1-6.9-9.5-10.2c5.1-20.3-6.2-37.9-6.2-37.9c-19.5-1.2-31.9%2c6.1-36.5%2c9.4c-0.8-0.3-1.5-0.7-2.3-1 c-3.3-1.3-6.7-2.6-10.3-3.7c-3.5-1.1-7.1-2.1-10.8-3c-3.7-0.9-7.4-1.6-11.2-2.2c-0.7-0.1-1.3-0.2-2-0.3 c-8.5-27.2-32.9-38.6-32.9-38.6c-27.3%2c17.3-32.4%2c41.5-32.4%2c41.5s-0.1%2c0.5-0.3%2c1.4c-1.5%2c0.4-3%2c0.9-4.5%2c1.3c-2.1%2c0.6-4.2%2c1.4-6.2%2c2.2 c-2.1%2c0.8-4.1%2c1.6-6.2%2c2.5c-4.1%2c1.8-8.2%2c3.8-12.2%2c6c-3.9%2c2.2-7.7%2c4.6-11.4%2c7.1c-0.5-0.2-1-0.4-1-0.4c-37.8-14.4-71.3%2c2.9-71.3%2c2.9 c-3.1%2c40.2%2c15.1%2c65.5%2c18.7%2c70.1c-0.9%2c2.5-1.7%2c5-2.5%2c7.5c-2.8%2c9.1-4.9%2c18.4-6.2%2c28.1c-0.2%2c1.4-0.4%2c2.8-0.5%2c4.2 C18.8%2c192.7%2c8.5%2c228%2c8.5%2c228c29.1%2c33.5%2c63.1%2c35.6%2c63.1%2c35.6c0%2c0%2c0.1-0.1%2c0.1-0.1c4.3%2c7.7%2c9.3%2c15%2c14.9%2c21.9c2.4%2c2.9%2c4.8%2c5.6%2c7.4%2c8.3 c-10.6%2c30.4%2c1.5%2c55.6%2c1.5%2c55.6c32.4%2c1.2%2c53.7-14.2%2c58.2-17.7c3.2%2c1.1%2c6.5%2c2.1%2c9.8%2c2.9c10%2c2.6%2c20.2%2c4.1%2c30.4%2c4.5 c2.5%2c0.1%2c5.1%2c0.2%2c7.6%2c0.1l1.2%2c0l0.8%2c0l1.6%2c0l1.6-0.1l0%2c0.1c15.3%2c21.8%2c42.1%2c24.9%2c42.1%2c24.9c19.1-20.1%2c20.2-40.1%2c20.2-44.4l0%2c0 c0%2c0%2c0-0.1%2c0-0.3c0-0.4%2c0-0.6%2c0-0.6l0%2c0c0-0.3%2c0-0.6%2c0-0.9c4-2.8%2c7.8-5.8%2c11.4-9.1c7.6-6.9%2c14.3-14.8%2c19.9-23.3 c0.5-0.8%2c1-1.6%2c1.5-2.4c21.6%2c1.2%2c36.9-13.4%2c36.9-13.4c-3.6-22.5-16.4-33.5-19.1-35.6l0%2c0c0%2c0-0.1-0.1-0.3-0.2 c-0.2-0.1-0.2-0.2-0.2-0.2c0%2c0%2c0%2c0%2c0%2c0c-0.1-0.1-0.3-0.2-0.5-0.3c0.1-1.4%2c0.2-2.7%2c0.3-4.1c0.2-2.4%2c0.2-4.9%2c0.2-7.3l0-1.8l0-0.9 l0-0.5c0-0.6%2c0-0.4%2c0-0.6l-0.1-1.5l-0.1-2c0-0.7-0.1-1.3-0.2-1.9c-0.1-0.6-0.1-1.3-0.2-1.9l-0.2-1.9l-0.3-1.9 c-0.4-2.5-0.8-4.9-1.4-7.4c-2.3-9.7-6.1-18.9-11-27.2c-5-8.3-11.2-15.6-18.3-21.8c-7-6.2-14.9-11.2-23.1-14.9 c-8.3-3.7-16.9-6.1-25.5-7.2c-4.3-0.6-8.6-0.8-12.9-0.7l-1.6%2c0l-0.4%2c0c-0.1%2c0-0.6%2c0-0.5%2c0l-0.7%2c0l-1.6%2c0.1c-0.6%2c0-1.2%2c0.1-1.7%2c0.1 c-2.2%2c0.2-4.4%2c0.5-6.5%2c0.9c-8.6%2c1.6-16.7%2c4.7-23.8%2c9c-7.1%2c4.3-13.3%2c9.6-18.3%2c15.6c-5%2c6-8.9%2c12.7-11.6%2c19.6c-2.7%2c6.9-4.2%2c14.1-4.6%2c21 c-0.1%2c1.7-0.1%2c3.5-0.1%2c5.2c0%2c0.4%2c0%2c0.9%2c0%2c1.3l0.1%2c1.4c0.1%2c0.8%2c0.1%2c1.7%2c0.2%2c2.5c0.3%2c3.5%2c1%2c6.9%2c1.9%2c10.1c1.9%2c6.5%2c4.9%2c12.4%2c8.6%2c17.4 c3.7%2c5%2c8.2%2c9.1%2c12.9%2c12.4c4.7%2c3.2%2c9.8%2c5.5%2c14.8%2c7c5%2c1.5%2c10%2c2.1%2c14.7%2c2.1c0.6%2c0%2c1.2%2c0%2c1.7%2c0c0.3%2c0%2c0.6%2c0%2c0.9%2c0c0.3%2c0%2c0.6%2c0%2c0.9-0.1 c0.5%2c0%2c1-0.1%2c1.5-0.1c0.1%2c0%2c0.3%2c0%2c0.4-0.1l0.5-0.1c0.3%2c0%2c0.6-0.1%2c0.9-0.1c0.6-0.1%2c1.1-0.2%2c1.7-0.3c0.6-0.1%2c1.1-0.2%2c1.6-0.4 c1.1-0.2%2c2.1-0.6%2c3.1-0.9c2-0.7%2c4-1.5%2c5.7-2.4c1.8-0.9%2c3.4-2%2c5-3c0.4-0.3%2c0.9-0.6%2c1.3-1c1.6-1.3%2c1.9-3.7%2c0.6-5.3 c-1.1-1.4-3.1-1.8-4.7-0.9c-0.4%2c0.2-0.8%2c0.4-1.2%2c0.6c-1.4%2c0.7-2.8%2c1.3-4.3%2c1.8c-1.5%2c0.5-3.1%2c0.9-4.7%2c1.2c-0.8%2c0.1-1.6%2c0.2-2.5%2c0.3 c-0.4%2c0-0.8%2c0.1-1.3%2c0.1c-0.4%2c0-0.9%2c0-1.2%2c0c-0.4%2c0-0.8%2c0-1.2%2c0c-0.5%2c0-1%2c0-1.5-0.1c0%2c0-0.3%2c0-0.1%2c0l-0.2%2c0l-0.3%2c0 c-0.2%2c0-0.5%2c0-0.7-0.1c-0.5-0.1-0.9-0.1-1.4-0.2c-3.7-0.5-7.4-1.6-10.9-3.2c-3.6-1.6-7-3.8-10.1-6.6c-3.1-2.8-5.8-6.1-7.9-9.9 c-2.1-3.8-3.6-8-4.3-12.4c-0.3-2.2-0.5-4.5-0.4-6.7c0-0.6%2c0.1-1.2%2c0.1-1.8c0%2c0.2%2c0-0.1%2c0-0.1l0-0.2l0-0.5c0-0.3%2c0.1-0.6%2c0.1-0.9 c0.1-1.2%2c0.3-2.4%2c0.5-3.6c1.7-9.6%2c6.5-19%2c13.9-26.1c1.9-1.8%2c3.9-3.4%2c6-4.9c2.1-1.5%2c4.4-2.8%2c6.8-3.9c2.4-1.1%2c4.8-2%2c7.4-2.7 c2.5-0.7%2c5.1-1.1%2c7.8-1.4c1.3-0.1%2c2.6-0.2%2c4-0.2c0.4%2c0%2c0.6%2c0%2c0.9%2c0l1.1%2c0l0.7%2c0c0.3%2c0%2c0%2c0%2c0.1%2c0l0.3%2c0l1.1%2c0.1 c2.9%2c0.2%2c5.7%2c0.6%2c8.5%2c1.3c5.6%2c1.2%2c11.1%2c3.3%2c16.2%2c6.1c10.2%2c5.7%2c18.9%2c14.5%2c24.2%2c25.1c2.7%2c5.3%2c4.6%2c11%2c5.5%2c16.9c0.2%2c1.5%2c0.4%2c3%2c0.5%2c4.5 l0.1%2c1.1l0.1%2c1.1c0%2c0.4%2c0%2c0.8%2c0%2c1.1c0%2c0.4%2c0%2c0.8%2c0%2c1.1l0%2c1l0%2c1.1c0%2c0.7-0.1%2c1.9-0.1%2c2.6c-0.1%2c1.6-0.3%2c3.3-0.5%2c4.9 c-0.2%2c1.6-0.5%2c3.2-0.8%2c4.8c-0.3%2c1.6-0.7%2c3.2-1.1%2c4.7c-0.8%2c3.1-1.8%2c6.2-3%2c9.3c-2.4%2c6-5.6%2c11.8-9.4%2c17.1 c-7.7%2c10.6-18.2%2c19.2-30.2%2c24.7c-6%2c2.7-12.3%2c4.7-18.8%2c5.7c-3.2%2c0.6-6.5%2c0.9-9.8%2c1l-0.6%2c0l-0.5%2c0l-1.1%2c0l-1.6%2c0l-0.8%2c0 c0.4%2c0-0.1%2c0-0.1%2c0l-0.3%2c0c-1.8%2c0-3.5-0.1-5.3-0.3c-7-0.5-13.9-1.8-20.7-3.7c-6.7-1.9-13.2-4.6-19.4-7.8 c-12.3-6.6-23.4-15.6-32-26.5c-4.3-5.4-8.1-11.3-11.2-17.4c-3.1-6.1-5.6-12.6-7.4-19.1c-1.8-6.6-2.9-13.3-3.4-20.1l-0.1-1.3l0-0.3 l0-0.3l0-0.6l0-1.1l0-0.3l0-0.4l0-0.8l0-1.6l0-0.3c0%2c0%2c0%2c0.1%2c0-0.1l0-0.6c0-0.8%2c0-1.7%2c0-2.5c0.1-3.3%2c0.4-6.8%2c0.8-10.2 c0.4-3.4%2c1-6.9%2c1.7-10.3c0.7-3.4%2c1.5-6.8%2c2.5-10.2c1.9-6.7%2c4.3-13.2%2c7.1-19.3c5.7-12.2%2c13.1-23.1%2c22-31.8c2.2-2.2%2c4.5-4.2%2c6.9-6.2 c2.4-1.9%2c4.9-3.7%2c7.5-5.4c2.5-1.7%2c5.2-3.2%2c7.9-4.6c1.3-0.7%2c2.7-1.4%2c4.1-2c0.7-0.3%2c1.4-0.6%2c2.1-0.9c0.7-0.3%2c1.4-0.6%2c2.1-0.9 c2.8-1.2%2c5.7-2.2%2c8.7-3.1c0.7-0.2%2c1.5-0.4%2c2.2-0.7c0.7-0.2%2c1.5-0.4%2c2.2-0.6c1.5-0.4%2c3-0.8%2c4.5-1.1c0.7-0.2%2c1.5-0.3%2c2.3-0.5 c0.8-0.2%2c1.5-0.3%2c2.3-0.5c0.8-0.1%2c1.5-0.3%2c2.3-0.4l1.1-0.2l1.2-0.2c0.8-0.1%2c1.5-0.2%2c2.3-0.3c0.9-0.1%2c1.7-0.2%2c2.6-0.3 c0.7-0.1%2c1.9-0.2%2c2.6-0.3c0.5-0.1%2c1.1-0.1%2c1.6-0.2l1.1-0.1l0.5-0.1l0.6%2c0c0.9-0.1%2c1.7-0.1%2c2.6-0.2l1.3-0.1c0%2c0%2c0.5%2c0%2c0.1%2c0l0.3%2c0 l0.6%2c0c0.7%2c0%2c1.5-0.1%2c2.2-0.1c2.9-0.1%2c5.9-0.1%2c8.8%2c0c5.8%2c0.2%2c11.5%2c0.9%2c17%2c1.9c11.1%2c2.1%2c21.5%2c5.6%2c31%2c10.3 c9.5%2c4.6%2c17.9%2c10.3%2c25.3%2c16.5c0.5%2c0.4%2c0.9%2c0.8%2c1.4%2c1.2c0.4%2c0.4%2c0.9%2c0.8%2c1.3%2c1.2c0.9%2c0.8%2c1.7%2c1.6%2c2.6%2c2.4c0.9%2c0.8%2c1.7%2c1.6%2c2.5%2c2.4 c0.8%2c0.8%2c1.6%2c1.6%2c2.4%2c2.5c3.1%2c3.3%2c6%2c6.6%2c8.6%2c10c5.2%2c6.7%2c9.4%2c13.5%2c12.7%2c19.9c0.2%2c0.4%2c0.4%2c0.8%2c0.6%2c1.2c0.2%2c0.4%2c0.4%2c0.8%2c0.6%2c1.2 c0.4%2c0.8%2c0.8%2c1.6%2c1.1%2c2.4c0.4%2c0.8%2c0.7%2c1.5%2c1.1%2c2.3c0.3%2c0.8%2c0.7%2c1.5%2c1%2c2.3c1.2%2c3%2c2.4%2c5.9%2c3.3%2c8.6c1.5%2c4.4%2c2.6%2c8.3%2c3.5%2c11.7 c0.3%2c1.4%2c1.6%2c2.3%2c3%2c2.1c1.5-0.1%2c2.6-1.3%2c2.6-2.8C342.6%2c170.4%2c342.5%2c166.1%2c342%2c161.2z'/%3e %3c/svg%3e");
Actually it is not throwing any error, but printing lot of details like this. I don't know where is the error in it
Is somebody help me how to track this issue and solve it....
If I not mistaken some of the parameters of the dashboard are unique (like id, or uid).
So you will need to create a copy of your json file, then delete this parameter in one of your copies, and then try to import it.
