I am trying to import the dashboard via API. Hitting 500 from grafana.
Tried with 6.0 and 6.3-beta1, the same OS: Ubuntu, 16.04.
Grafana runs as systemd service.
Any idea?
Thanks,
Milan
Here is the curl:
curl -XPOST http://admin:admin@localhost:3000/api/dashboards/import -H "Content-Type: application/json" --data-binary @/Users/agaton/jvm.json
And here is the exception:
Jul 16 13:29:09 jumio-bi grafana-server[8109]: t=2019-07-16T13:29:09+0200 lvl=eror msg="Request error" logger=context userId=1 orgId=1 uname=admin error="runtime error: invalid memory address or nil pointer dereference" stack="/usr/local/
go/src/runtime/panic.go:82 (0x44e200)\n/usr/local/go/src/runtime/signal_unix.go:390 (0x44e02f)\n/go/src/github.com/grafana/grafana/pkg/components/simplejson/simplejson.go:142 (0xa2fd41)\n/go/src/github.com/grafana/grafana/pkg/components/s
implejson/simplejson.go:142 (0xa2fd41)\n/go/src/github.com/grafana/grafana/pkg/models/dashboards.go:130 (0xa2fd40)\n/go/src/github.com/grafana/grafana/pkg/plugins/dashboard_importer.go:55 (0xc7e994)\n/usr/local/go/src/reflect/value.go:447
(0x491bf0)\n/usr/local/go/src/reflect/value.go:308 (0x491673)\n/go/src/github.com/grafana/grafana/pkg/bus/bus.go:131 (0xa22651)\n/go/src/github.com/grafana/grafana/pkg/bus/bus.go:216 (0x124a003)\n/go/src/github.com/grafana/grafana/pkg/ap
i/plugins.go:194 (0x1249fe1)\n/usr/local/go/src/reflect/value.go:447 (0x491bf0)\n/usr/local/go/src/reflect/value.go:308 (0x491673)\n/go/src/github.com/grafana/grafana/vendor/github.com/go-macaron/inject/inject.go:177 (0x81a5c6)\n/go/src/g
ithub.com/grafana/grafana/vendor/github.com/go-macaron/inject/inject.go:137 (0x819ebb)\n/go/src/github.com/grafana/grafana/pkg/api/common.go:37 (0x126160d)\n/usr/local/go/src/reflect/value.go:447 (0x491bf0)\n/usr/local/go/src/reflect/valu
e.go:308 (0x491673)\n/go/src/github.com/grafana/grafana/vendor/github.com/go-macaron/inject/inject.go:177 (0x81a5c6)\n/go/src/github.com/grafana/grafana/vendor/github.com/go-macaron/inject/inject.go:137 (0x819ebb)\n/go/src/github.com/graf
ana/grafana/vendor/gopkg.in/macaron.v1/context.go:121 (0x81b679)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/context.go:112 (0xbace4e)\n/go/src/github.com/grafana/grafana/pkg/middleware/request_tracing.go:25 (0xbace41)\
Jul 16 13:29:09 jumio-bi grafana-server[8109]: 81a5c6)\n/go/src/github.com/grafana/grafana/vendor/github.com/go-macaron/inject/inject.go:137 (0x819ebb)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/context.go:121 (0x81b67
9)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/context.go:112 (0xbac66c)\n/go/src/github.com/grafana/grafana/pkg/middleware/request_metrics.go:17 (0xbac657)\n/usr/local/go/src/reflect/value.go:447 (0x491bf0)\n/usr/local
/go/src/reflect/value.go:308 (0x491673)\n/go/src/github.com/grafana/grafana/vendor/github.com/go-macaron/inject/inject.go:177 (0x81a5c6)\n/go/src/github.com/grafana/grafana/vendor/github.com/go-macaron/inject/inject.go:137 (0x819ebb)\n/go
/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/context.go:121 (0x81b679)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/context.go:112 (0xbac585)\n/go/src/github.com/grafana/grafana/pkg/middleware/recovery.go:1
47 (0xbac573)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/context.go:79 (0x81b520)\n/go/src/github.com/grafana/grafana/vendor/github.com/go-macaron/inject/inject.go:157 (0x81a280)\n/go/src/github.com/grafana/grafana/ven
dor/github.com/go-macaron/inject/inject.go:135 (0x819faa)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/context.go:121 (0x81b679)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/context.go:112 (0xba9a9b)\n/
go/src/github.com/grafana/grafana/pkg/middleware/logger.go:34 (0xba9a86)\n/usr/local/go/src/reflect/value.go:447 (0x491bf0)\n/usr/local/go/src/reflect/value.go:308 (0x491673)\n/go/src/github.com/grafana/grafana/vendor/github.com/go-macaro
n/inject/inject.go:177 (0x81a5c6)\n/go/src/github.com/grafana/grafana/vendor/github.com/go-macaron/inject/inject.go:137 (0x819ebb)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/context.go:121 (0x81b679)\n/go/src/github.co
m/grafana/grafana/vendor/gopkg.in/macaron.v1/router.go:187 (0x82ca26)\n/go/src/github.com/grafana/grafana/vendor/gopkg.in/macaron.v1/router.go:294 (0x82743d)\n/go/src/github.com/grafana/grafa
Jul 16 13:29:09 jumio-bi grafana-server[8109]: na/vendor/gopkg.in/macaron.v1/macaron.go:220 (0x8206cc)\n/usr/local/go/src/net/http/server.go:2774 (0x6f13b7)\n/usr/local/go/src/net/http/server.go:1878 (0x6ed0a0)\n/usr/local/go/src/runtime/
asm_amd64.s:1337 (0x4680e0)\n"
Jul 16 13:29:09 jumio-bi grafana-server[8109]: t=2019-07-16T13:29:09+0200 lvl=eror msg="Request Completed" logger=context userId=1 orgId=1 uname=admin method=POST path=/api/dashboards/import status=500 remote_addr=192.168.9.252 time_ms=20
6 size=122 referer=
The json is saved from https://grafana.com/grafana/dashboards/4701
