What Grafana version are you using?
Latest from docker “grafana/grafana”
What datasource are you using?
prometheus
What OS are you running grafana on?
Vagrant: bento/ubuntu-16.04
What did you do?
- Got dashboard json from here https://grafana.com/dashboards/893
- Created datasource Prometheus
- GUI import
paste JSONworks fine, though asks for prometheus datasource - Dashboard API does not work:
++++++ curl -v -L -s --fail -H 'Accept: application/json' -H 'Content-Type: application/json' -X POST -k http://admin:admin@192.168.99.10:3000/api/dashboards/db --data @commands/prom1/dashboards/main_rev5-src.json
* Trying 192.168.99.10...
* TCP_NODELAY set
* Connected to 192.168.99.10 (192.168.99.10) port 3000 (#0)
* Server auth using Basic with user 'admin'
> POST /api/dashboards/db HTTP/1.1
> Host: 192.168.99.10:3000
> Authorization: Basic YWRtaW46YWRtaW4=
> User-Agent: curl/7.57.0
> Content-Length: 56176
> Expect: 100-continue
< HTTP/1.1 100 Continue
} [16384 bytes data]
* We are completely uploaded and fine
* The requested URL returned error: 422 Unprocessable Entity
* stopped the pause stream!
* Closing connection 0
+++++ return 1
++++ exit 1
Can you please suggest a way to import dashboard?
