Grafana Version: 9.1.6
Operating System: linux
I am trying to automatically provision dashboards in Grafana using the dashboard provisioning feature. The dashboards are defined in JSON format and located at/etc/grafana/provisioning/dashboards/general. -
I have configured Grafana for dashboard provisioning using a Kubernetes ConfigMap that mounts dashboard JSON files and provisioning configuration files to the appropriate paths within the Grafana container. -
What happened?
The dashboards do not appear in the Grafana UI under the “General” folder as expected. However, when I import the JSON files manually through the UI, the dashboards work fine. -
I expected the dashboards to be automatically visible in the Grafana UI under the “General” folder without having to manually import them. -
apiVersion: apps/v1
kind: Deployment
metadata:
annotations:
deployment.kubernetes.io/revision: "6"
meta.helm.sh/release-name: grafana
meta.helm.sh/release-namespace: grafana
creationTimestamp: "2024-03-04T18:06:04Z"
generation: 6
labels:
app.kubernetes.io/instance: grafana
app.kubernetes.io/managed-by: Helm
app.kubernetes.io/name: grafana
app.kubernetes.io/version: 9.1.6
helm.sh/chart: grafana-6.39.0
namespace: grafana
spec:
template:
metadata:
annotations:
checksum/config: 454bfd6829a9f6c2db1b6418c718e909efcffaddfb8711c07d60c6a2556d7ece
checksum/dashboards-json-config: f4880f90654d3af50cce578f8b210a2eccbccf1f8ec4318fd7598dd1cd7ee129
checksum/sc-dashboard-provider-config: 01ba4719c80b6fe911b091a7c05124b64eeece964e09c058ef8f9805daca546b
checksum/secret: d56ddafb876aac484a64a749e99df0d75f36683da1c3b30856bd4d74bbd66153
spec:
containers:
- env:
- name: GF_SECURITY_ADMIN_USER
valueFrom:
secretKeyRef:
key: admin-user
- name: GF_SECURITY_ADMIN_PASSWORD
valueFrom:
secretKeyRef:
key: admin-password
- name: GF_PATHS_DATA
value: /var/lib/grafana/
- name: GF_PATHS_LOGS
value: /var/log/grafana
- name: GF_PATHS_PLUGINS
value: /var/lib/grafana/plugins
- name: GF_PATHS_PROVISIONING
value: /etc/grafana/provisioning
image: container-registry.ubs.net/grafana:9.1.6
volumeMounts:
- mountPath: /etc/grafana/grafana.ini
subPath: grafana.ini
- mountPath: /var/lib/grafana
- mountPath: /etc/grafana/provisioning/dashboards/general/customer.json
subPath: customer.json
- mountPath: /etc/grafana/provisioning/dashboards/general/kafka.json
subPath: kafka.json
- mountPath: /etc/grafana/provisioning/dashboards/general/kubernetes.json
subPath: kubernetes.json
- mountPath: /etc/grafana/provisioning/dashboards/general/mysql.json
subPath: mysql.json
- mountPath: /etc/grafana/provisioning/dashboards/general/opensearch.json
subPath: opensearch.json
- mountPath: /etc/grafana/provisioning/dashboards/general/rabbitmq.json
subPath: rabbitmq.json
- mountPath: /etc/grafana/provisioning/dashboards/general/redis.json
subPath: redis.json
- mountPath: /etc/grafana/provisioning/datasources/datasources.yaml
subPath: datasources.yaml
volumes:
- configMap:
- configMap:
- emptyDir: {}
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
I have not noticed any explicit errors in the Grafana UI.
- Did you follow any online instructions? If so, what is the URL?
I followed the general instructions for dashboard provisioning from the official Grafana documentation
