5.1.2 -
I am deploying Grafana via Helm and have couple custom dashboards I would like to import while installing. -
As of today, those custom dashboards are stored as JSON file (one file per dashboard) in a folder.
It works but I do have to explicitly declare all dashboards to import where I would like to have a way to have those automatically imported without having to declare it. For example, if I add a new dashboard JSON file to the folder, I would like it to be loaded automatically without having to declare / import it. -
What happened?
Dashboards are imported but needs to be declared indashboardssection. -
Have dashboards listed into the dashboards folders imported automatically without having to explicitly declare each dashboard manually. -
Here’s my dashboards section:
dashboards:
default:
node-exporter:
file: dashboards/node-exporter.json
kubernetes-cluster:
file: dashboards/kubernetes-cluster.json
cert-manager:
file: dashboards/cert-manager.json
aws-limits:
file: dashboards/aws-limits.json
detailed-pods-resources:
file: dashboards/detailed-pods-resources.json
client-pod-usage:
file: dashboards/client_pod_usage.json
kubernetes-capacity-planning:
file: dashboards/kubernetes-capacity-planning.json
None -
Thanks a lot for you help ![]()
