8.1.x -
I want to ensure that our dashboards are created/updated from Bitbucket Repo each time the Grafana instance Pod is deployed on OpenShift. -
I have a Bitbucket Repo with a Dockerfile with content “FROM grafana/grafana:latest” only. Additionally I have a directory “dashboards” that contains two JSON files with our dashboards. Using Mounts/Volumes in OpenShift template.yaml and according commands in Jankinsfile (see below) I pass those files to Grafana Pod. -
What happened?
The files of the dashboards can be found inside the pod but dashboards are not shown in Grafana. -
I expect to see the dashboards in Grafana and that those are created/updated when the Pod is deployed. -
template.yaml
apiVersion: v1
kind: Template
metadata:
labels:
template: deployment-template
objects:
apiVersion: v1
kind: DeploymentConfig
metadata:
labels:
app: elan-grafana-instance
spec:
replicas: ${{REPLICAS}}
selector:
template:
metadata:
labels:
category: vertriebsbank
np/ruv-elan: provider
spec:
containers:
- name: elan-grafana-instance
image: ${REGISTRY}/${NAMESPACE}/${APP}:${VERSION}
imagePullPolicy: Always
ports:
- containerPort: 3000
protocol: TCP
resources:
requests:
memory: ${MEMORY_REQUEST}
cpu: ${CPU_REQUEST}
limits:
memory: ${MEMORY_LIMIT}
cpu: ${CPU_LIMIT}
volumeMounts:
- mountPath: /var/lib/grafana
- mountPath: /etc/grafana
- mountPath: /etc/grafana/provisioning/datasources
- mountPath: /etc/grafana/provisioning/dashboards
- mountPath: /grafana-dashboard-definitions/grafana-dashboards
- mountPath: /etc/grafana/provisioning/notifiers
- mountPath: /etc/grafana/provisioning/plugins
env:
- name: APP_VERSION
value: ‘${VERSION}’
- name: SERVER_PORT
value: ‘3000’
- name: GF_SECURITY_ADMIN_USER
value: elan
- name: GF_SECURITY_ADMIN_PASSWORD
value: elan
- name: MY_POD_NAMESPACE
valueFrom:
fieldRef:
fieldPath: metadata.namespace
- name: POD_IP
valueFrom:
fieldRef:
fieldPath: status.podIP
volumes:
- emptyDir: { }
- configMap:
defaultMode: 420
- name: grafana-datasources-provision
secret:
defaultMode: 420
secretName: elan-grafana-datasources
- configMap:
defaultMode: 420
- configMap:
defaultMode: 420
- configMap:
defaultMode: 420
- emptyDir: { }
kind: Service
metadata:
labels:
spec:
selector:
ports:
- name: container
protocol: TCP
port: 3000
targetPort: 3000apiVersion: v1
kind: Route
metadata:
labels:
spec:
port:
targetPort: container
tls:
termination: edge
to:
kind: Service
kind: ConfigMap
metadata:
labels:
app: grafana-config-instance
data:
grafana.ini: |-
[paths]
data = /var/lib/grafana
logs = /var/lib/grafana/logs
plugins = /var/lib/grafana/plugins
provisioning = /etc/grafana/provisioning
[smtp]
enabled = ${ALERTING_ENABLED}
host = mailgateway.default.svc:25
from_address = …
skip_verify = trueapiVersion: v1
kind: ConfigMap
metadata:
labels:
app: grafana-notifiers-provision
data:
notifiers.yaml: |-
notifiers:
- name: Developer Mail
type: email
uid: developermail
org_id: 1
is_default: true
disable_resolve_message: true
send_reminder: true
frequency: 2h
settings:
singleEmail: true
uploadImage: true
addresses: …
parameters:name: NAMESPACE
required: truename: VERSION
required: truename: REGISTRY
required: truename: MONITOR_API_VERSION
displayName: Application Name
description: The name of your application and of your image
required: true
value: elan-grafana-instancename: REPLICAS
displayName: Replicas.
description: Replicas of the application to run.
required: truename: MEMORY_LIMIT
displayName: Memory Limit
value: “4Gi”name: MEMORY_REQUEST
displayName: Memory Request
value: “200Mi”
required: truename: CPU_LIMIT
displayName: CPU Limit
value: “500m”name: CPU_REQUEST
displayName: CPU Request
value: “10m”name: ALERTING_ENABLED
displayName: Alerting switch
description: true for alerting enabled, false for alerting disabled
value: “true”
required: false
Part of Jenkinsfile
pipeline {
agent { label 'mvn11' }
environment {
APP = 'elan-grafana-instance'
RELEASE_NUMBER = 1
options {
buildDiscarder(logRotator(numToKeepStr: '4'))
stages {
stage('➁ Build') {
steps {
sh '''
oc delete configmap elan-grafana-dashboards --ignore-not-found=true
oc create configmap elan-grafana-dashboards --from-file=dashboards/
buildDockerImage(semVer: true)
No -
Do not understand this question
