Im using version=10.1.1
Im trying to start the containers with a dashboard but i cant mange to do it, i can set a datasource by putting it in /etc/grafana/provisioning/datasources
im mountin the dashboards as a ConfigMap, which has a json file and im setting in various paths, my manifest is:
apiVersion: apps/v1
kind: Deployment
metadata:
namespace : default
spec:
replicas: 1
selector:
matchLabels:
app: grafana
template:
metadata:
labels:
app: grafana
spec:
containers:
- name: grafana
image: grafana/grafana:latest
ports:
- containerPort: 3000
env:
- name: GF_INSTALL_PLUGINS
value: grafana-clock-panel,grafana-simple-json-datasource
volumeMounts:
- name: grafana-storage
mountPath: /var/lib/grafana
- name: datasource-config
mountPath: /etc/grafana/provisioning/datasources # Directorio de configuración automática de datasources
- name: dashboard-config
mountPath: /var/lib/grafana/dashboards/ # Directorio de configuración automática de dashboards
command: ["grafana-server"]
# - name: grafana-sc-dashboard
# image: quay.io/kiwigrid/k8s-sidecar:1.19.2
# env:
# - name: LABEL
# value: "grafana_dashboard"
# - name: FOLDER
# value: "/tmp/dashboards"
volumes:
emptyDir: {}
configMap:
configMap:
apiVersion: v1
kind: Service
metadata:
namespace: default
spec:
selector:
app: grafana
ports:
- protocol: TCP
port: 3000
targetPort: 3000
type: NodePort
i have tried paths putting the dashboards as:
/etc/grafana/provisioning/dashboards
/etc/grafana/dashboards
but none seem to work
and the configMap:
apiVersion: v1
kind: ConfigMap
metadata:
labels:
grafana_dashboard: "1"
data:
prometheus-dashboard.json: | # Nombre del archivo debe coincidir con el que se monta en el ConfigMap
"__inputs": [
"name": "DS_PROMETHEUS",
"label": "Prometheus",
"description": "",
"type": "datasource",
"pluginId": "prometheus",
"pluginName": "Prometheus"
"__elements": {},
"__requires": [
"type": "grafana",
"id": "grafana",
"name": "Grafana",
"version": "10.1.0"
"id": "prometheus",
"name": "Prometheus",
"version": "1.0.0"
"type": "panel",
"id": "timeseries",
"name": "Time series",
"version": ""
"annotations": {
"list": [
"builtIn": 1,
"datasource": {
"type": "grafana",
"uid": "-- Grafana --"
"enable": true,
"hide": true,
"iconColor": "rgba(0, 211, 255, 1)",
"name": "Annotations & Alerts",
"type": "dashboard"
"editable": true,
"fiscalYearStartMonth": 0,
"graphTooltip": 0,
"id": null,
"links": [],
"liveNow": false,
"panels": [
"datasource": {
"type": "prometheus",
"uid": "${DS_PROMETHEUS}"
"fieldConfig": {
"defaults": {
"color": {
"mode": "palette-classic"
"custom": {
"axisCenteredZero": false,
"axisColorMode": "text",
"axisLabel": "",
"axisPlacement": "auto",
"barAlignment": 0,
"drawStyle": "line",
"fillOpacity": 0,
"gradientMode": "none",
"hideFrom": {
"legend": false,
"tooltip": false,
"viz": false
"insertNulls": false,
"lineInterpolation": "linear",
"lineWidth": 1,
"pointSize": 5,
"scaleDistribution": {
"type": "linear"
"showPoints": "auto",
"spanNulls": false,
"stacking": {
"group": "A",
"mode": "none"
"thresholdsStyle": {
"mode": "off"
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"overrides": []
"gridPos": {
"h": 8,
"w": 12,
"x": 0,
"y": 0
"id": 1,
"options": {
"legend": {
"calcs": [],
"displayMode": "list",
"placement": "bottom",
"showLegend": true
"tooltip": {
"mode": "single",
"sort": "none"
"targets": [
"datasource": {
"disableTextWrap": false,
"editorMode": "builder",
"expr": "calls_answered_total",
"fullMetaSearch": false,
"includeNullMetadata": true,
"instant": false,
"legendFormat": "__auto",
"range": true,
"refId": "A",
"useBackend": false
"title": "Panel Title",
"type": "timeseries"
"refresh": "",
"schemaVersion": 38,
"style": "dark",
"tags": [],
"templating": {
"list": []
"time": {
"from": "now-6h",
"to": "now"
"timepicker": {},
"timezone": "",
"title": "prometheusds",
"uid": "d06a116f-3b68-4cd6-849c-61c76d45562b",
"version": 1,
"weekStart": ""
the dashboards doesnt appear
this are the start and the end of the logs if they are of use:
Deprecation warning: The standalone 'grafana-server' program is deprecated and will be removed in the future. Please update all uses of 'grafana-server' to 'grafana server'
logger=settings t=2023-09-04T18:11:09.252960235Z level=info msg="Starting Grafana" version=10.1.1 commit=0cfa76b22d branch=HEAD compiled=2023-08-31T17:47:57Z
logger=settings t=2023-09-04T18:11:09.253175672Z level=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-09-04T18:11:09.253196984Z level=info msg="Config overridden from Environment variable" var="GF_PATHS_DATA=/var/lib/grafana"
logger=settings t=2023-09-04T18:11:09.253214823Z level=info msg="Config overridden from Environment variable" var="GF_PATHS_LOGS=/var/log/grafana"
logger=settings t=2023-09-04T18:11:09.253227114Z level=info msg="Config overridden from Environment variable" var="GF_PATHS_PLUGINS=/var/lib/grafana/plugins"
logger=settings t=2023-09-04T18:11:09.253241176Z level=info msg="Config overridden from Environment variable" var="GF_PATHS_PROVISIONING=/etc/grafana/provisioning"
logger=settings t=2023-09-04T18:11:09.253256165Z level=info msg=Target target=[all]
logger=settings t=2023-09-04T18:11:09.253273498Z level=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2023-09-04T18:11:09.253285906Z level=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2023-09-04T18:11:09.253297548Z level=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2023-09-04T18:11:09.253309096Z level=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2023-09-04T18:11:09.253320974Z level=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2023-09-04T18:11:09.253332179Z level=info msg="App mode production"
logger=sqlstore t=2023-09-04T18:11:09.253568747Z level=info msg="Connecting to DB" dbtype=sqlite3
logger=sqlstore t=2023-09-04T18:11:09.253588904Z level=info msg="Creating SQLite database file" path=/var/lib/grafana/grafana.db
logger=secrets t=2023-09-04T18:11:11.212550559Z level=info msg="Envelope encryption state" enabled=true currentprovider=secretKey.v1
logger=local.finder t=2023-09-04T18:11:11.292242172Z level=warn msg="Skipping finding plugins as directory does not exist" path=/usr/share/grafana/plugins-bundled
logger=local.finder t=2023-09-04T18:11:11.292280996Z level=warn msg="Skipping finding plugins as directory does not exist" path=/var/lib/grafana/plugins
logger=query_data t=2023-09-04T18:11:11.295890007Z level=info msg="Query Service initialization"
logger=live.push_http t=2023-09-04T18:11:11.298431883Z level=info msg="Live Push Gateway initialization"
logger=infra.usagestats.collector t=2023-09-04T18:11:14.740739417Z level=info msg="registering usage stat providers" usageStatsProvidersLen=2
logger=modules t=2023-09-04T18:11:14.740950587Z level=info msg=initialising module=secret-migrator
logger=modules t=2023-09-04T18:11:14.740945623Z level=info msg=initialising module=http-server
logger=http.server t=2023-09-04T18:11:14.744230483Z level=info msg="HTTP Server Listen" address=[::]:3000 protocol=http subUrl= socket=
logger=modules t=2023-09-04T18:11:14.747429814Z level=info msg=initialising module=provisioning
logger=provisioning.datasources t=2023-09-04T18:11:14.748752362Z level=info msg="inserting datasource from configuration " name=Prometheus uid=PBFA97CFB590B2093
logger=provisioning.alerting t=2023-09-04T18:11:14.813304124Z level=info msg="starting to provision alerting"
logger=provisioning.alerting t=2023-09-04T18:11:14.813346489Z level=info msg="finished to provision alerting"
logger=modules t=2023-09-04T18:11:14.813396337Z level=info msg=initialising module=background-services
logger=modules t=2023-09-04T18:11:14.813645385Z level=info msg="All modules healthy" modules="[http-server secret-migrator provisioning background-services]"
logger=grafanaStorageLogger t=2023-09-04T18:11:14.813700123Z level=info msg="storage starting"
logger=ngalert.state.manager t=2023-09-04T18:11:14.813733544Z level=info msg="Warming state cache for startup"
logger=ngalert.state.manager t=2023-09-04T18:11:14.848984036Z level=info msg="State cache has been initialized" states=0 duration=35.249022ms
logger=ngalert.multiorg.alertmanager t=2023-09-04T18:11:14.849050187Z level=info msg="Starting MultiOrg Alertmanager"
logger=ngalert.scheduler t=2023-09-04T18:11:14.849046154Z level=info msg="Starting scheduler" tickInterval=10s
logger=ticker t=2023-09-04T18:11:14.849119843Z level=info msg=starting first_tick=2023-09-04T18:11:20Z
logger=grafana.update.checker t=2023-09-04T18:11:14.897584319Z level=info msg="Update check succeeded" duration=83.938116ms
logger=plugins.update.checker t=2023-09-04T18:11:15.084617647Z level=info msg="Update check succeeded" duration=271.075462ms
logger=authn.service t=2023-09-04T18:11:43.244339181Z level=warn msg="Failed to authenticate request" client=auth.client.session error="user token not found"
logger=context userId=0 orgId=0 uname= t=2023-09-04T18:11:43.244402603Z level=warn msg=Unauthorized error="user token not found" remote_addr=127.0.0.1 traceID=
logger=context userId=0 orgId=0 uname= t=2023-09-04T18:11:43.244442889Z level=info msg="Request Completed" method=GET path=/api/live/ws status=401 remote_addr=127.0.0.1 time_ms=0 duration=525.341µs size=40 referer= handler=/api/live/ws
logger=authn.service t=2023-09-04T18:11:45.603576321Z level=warn msg="Failed to authenticate request" client=auth.client.session error="user token not found"
logger=context userId=0 orgId=0 uname= t=2023-09-04T18:11:45.603639059Z level=warn msg=Unauthorized error="user token not found" remote_addr=127.0.0.1 traceID=
logger=context userId=0 orgId=0 uname= t=2023-09-04T18:11:45.603685894Z level=info msg="Request Completed" method=GET path=/api/live/ws status=401 remote_addr=127.0.0.1 time_ms=0 duration=609.996µs size=40 referer= handler=/api/live/ws
logger=authn.service t=2023-09-04T18:11:47.878941021Z level=warn msg="Failed to authenticate request" client=auth.client.session error="user token not found"
logger=context userId=0 orgId=0 uname= t=2023-09-04T18:11:47.87902324Z level=info msg="Request Completed" method=GET path=/ status=302 remote_addr=127.0.0.1 time_ms=0 duration=545.069µs size=29 referer=http://localhost:3000/login handler=/
logger=authn.service t=2023-09-04T18:11:47.881146539Z level=warn msg="Failed to authenticate request" client=auth.client.session error="user token not found"
logger=authn.service t=2023-09-04T18:11:51.156162711Z level=warn msg="Failed to authenticate request" client=auth.client.session error="user token not found"
logger=context userId=1 orgId=1 uname=admin t=2023-09-04T18:11:53.935837553Z level=info msg="Request Completed" method=GET path=/api/live/ws status=-1 remote_addr=127.0.0.1 time_ms=1 duration=1.712808ms size=0 referer= handler=/api/live/ws
logger=infra.usagestats t=2023-09-04T18:12:31.817108831Z level=info msg="Usage stats are ready to report"
