Hello everyone!
I’m having an issue with provisioning dashboards with Grafana Operator.
11.2.1
I’m looking into deploying the same dashboard via GitOps for many namespaces (dashboard shows resource usage and logs for all pods in team’s namespace) and would prefer not to have to click variable config UI buttons for a dashboard to load data.
The dashboard appears but data on it doesn’t until I go to Prometheus datasource query variable used by the dashboard (returns list of clusters) and hit the “Run query” button once and hit the “Apply”. Imgur: The magic of the Internet
After that, the dashboard works fine.
Adding preconfigured dashboard JSON to GrafanaDashboard CRD YAML manifest.
What happened?
Dashboard got deployed but didn’t display any data - all panels were empty.
Dashboard to fully load data in all panels.
Dashboard JSON: Source Code | zutgz | Rocket Powered Pastebin
How dashboard looks after deployment: Imgur: The magic of the Internet
Error message (disappears after Prometheus datasource retrieves cluster names):
parse error : queries require at least one regexp or equality matcher that does not have an empty-compatible value. For instance, app=~".*" does not meet this requirement, but app=~".+" will
