Running grafana enterprise 9.4.7. Default data source is prometheus 2.43.
I have two instances of grafana/prometheus. One is hosted and one is local.
I want to backup the hosted instance to my local instance.
On the hosted instance I export the dashboard json and download to my local machine.
On the local instance I import the dashboard json and it loads, shows the panels, time settings, etc but no data.
Looking inside each panel I see the query title is there but no query code. When I click the arrow to expand the query to see it’s config it does not expand. Looks like the query code is missing, empty.
Within the panel I change the data source to not prometheus and change it back to prometheus. Now the query code is there and clicking run query shows the data.
Is this a bug or am I missing something?
I am doing this as a way to manually backup my dashboards. Once I understand how the process works and can do it manually I will automate this.
