Grafana cloud
- What are you trying to achieve?
I’m trying to stack several time series of dissimilar Y scale (e.g. A is between 1k-2k and B is between 0 and 1) on top of each other - each series graphed on its own without being overlayed on top of other series, akin to:
Most importantly, the vertical line at cursor needs to line up on all graphs simultaneously to assist viewing correlated values across all series. For this reason creating multiple time series panels doesn’t help.
Learn Grafana: How to use dual axis graphs | Grafana Labs comes very close, is there a way to avoid overlaying, and instead put each series on its own graph?
Thanks!
