How to get both prefix and suffix in stat panel?
I am trying to get my single stat panel to display both a prefix unit and a suffix unit, and display something like “£2.99 per day”. Currently I cannot achieve both at the same time:
The github says “this was added”, but I cannot see any option for it.
https://github.com/grafana/grafana/discussions/39533
hello @ppxtb please confirm is this your requirement??
Yep - how please? Can’t seem to make the prefix:”value” and suffix:”value” work in combo in the Standard options > Unit
New dashboard 06-04-2026-1775459171959.json (2.7 KB)
Workaround in stat panel visualization.
Almost. I would like the same font size and colour though.
yes, you can
Text size increase.
color mode set to none.
Thanks, this workaround will do the job for now.
It’s still a shame they removed the suffix and prefix options that were present in earlier versions! :slight_smile:
