8.4.1 -
An stat-panel with prefix or suffix -
What happened?
There is no option to add a suffix or preffix -
Find out how to add a suffix -
In version 6:
In version 8:
Did you receive any errors in the Grafana UI or in related logs? No, I didn’t.
No, I didn’t.
Thanks.
