How to create a Grafana Dashboard for my OpenTelemetry instruments > Collector > Tempo setup
I am new to all this architecture, and I am a bit lost.
I have integrated all these instruments in my Rails application:
gem "opentelemetry-exporter-otlp"
gem "opentelemetry-instrumentation-mysql2"
gem "opentelemetry-instrumentation-net_http"
gem "opentelemetry-instrumentation-rack"
gem "opentelemetry-instrumentation-rails"
I am sending the metrics to an instance of OpenTelemetryCollector, and from there to a Tempo instance.
In Grafana, I have configured the Tempo datasource.
I can see the Traces in the Grafana > Explorer:
But I don’t know how to build a proper dashboard with it. I have tried to import a dashboard like this. But the data source is Prometheus, not Loki. The are only 2 dashboards for Tempo on this database. And they don’t look like the one I want.
I would like to see the requests, the statuses, the request_time, … as in the OpenTelemetry APM Dashboard
Any help?
If my architecture is wrong, I am also willing to change it.
See doc for OpenTelemetry APM Dashboard
  1. OpenTelemetry Collector: Receive traces and process them to metrics with Span Metrics Connector
  2. Prometheus: Scrape metrics from OpenTelemetry Collector
You are missing these steps (older collector versions have had spanmetricsprocessor, not connector) - this connector (processor) aggregates Request, Error and Duration (R.E.D) metrics from span data - so you will generate METRICS from TRACES and you will save these generated METRICS into metric storage - Prometheus.
Oh, that has sense. Very bad on me, I did not read the documentation of the dashboard. I will do it from now on.
@jangaraj does it means that I don’t need Tempo in my setup?
If you need only RED metrics, then you don’t need Tempo (traces).
But what will you do when your RED metrics show increased error rate or latency?
That’s exactly a showtime for traces: you will filter traces with error, increased latency, you’ll inspect them and you will get a root cause (probably).
Thanks, I definetely need both. I’ll configure the Collector to export metrics to Prometheus and at the same time keeping sending them to Tempo.
