OpenTelemetry Collector to Tempo
Hi, i want to use Opentelemetry Collector to export my traces to Tempo (v2.6.1).
Opentelemetry tries to send (via HTTP) the endpoints to /v1/traces but tempo only accept /api/traces and /api/v2/traces.
does someone have a similar issue and maybe know how to handle it?
Enable/use otlp receiver:
thank you @jangaraj
I already enabled OTLP :thinking:
stream_over_http_enabled: true
server:
  http_listen_port: 3200
  grpc_listen_port: 3201
  log_level: info
query_frontend:
  search:
    duration_slo: 5s
    throughput_bytes_slo: 1.073741824e+09
  trace_by_id:
    duration_slo: 5s
distributor:
  receivers:
    otlp:
      protocols:
        http:
        grpc:
compactor:
  compaction:
    block_retention: 1h # overall Tempo trace retention. set for demo purposes
metrics_generator:
  registry:
    external_labels:
      source: tempo
      cluster: docker-compose
  storage:
    path: /var/tempo/generator/wal
    remote_write:
      - url: http://prometheus:9090/api/v1/write
        send_exemplars: true
  traces_storage:
    path: /var/tempo/generator/traces
storage:
  trace:
    backend: local # backend configuration to use
    wal:
      path: /var/tempo/wal # where to store the wal locally
    local:
      path: /var/tempo/blocks
overrides:
  defaults:
    metrics_generator:
      processors: [service-graphs, span-metrics, local-blocks] # enables metrics generator
      generate_native_histograms: both
and here the available endpoints
GET /status/endpoints
| NAME                                        | REGEX                                             |
| /api/echo                                   | ^/api/echo$                                       |
| /api/metrics/query                          | ^/api/metrics/query$                              |
| /api/metrics/query_range                    | ^/api/metrics/query_range$                        |
| /api/metrics/summary                        | ^/api/metrics/summary$                            |
| /api/search                                 | ^/api/search$                                     |
| /api/search/tag/{tagName}/values            | ^/api/search/tag/(?P<v0>[^/]+)/values$            |
| /api/search/tags                            | ^/api/search/tags$                                |
| /api/status/buildinfo                       | ^/api/status/buildinfo$                           |
| /api/traces/{traceID}                       | ^/api/traces/(?P<v0>[^/]+)$                       |
| /api/v2/search/tag/{tagName}/values         | ^/api/v2/search/tag/(?P<v0>[^/]+)/values$         |
| /api/v2/search/tags                         | ^/api/v2/search/tags$                             |
| /api/v2/traces/{traceID}                    | ^/api/v2/traces/(?P<v0>[^/]+)$                    |
| /flush                                      | ^/flush$                                          |
| /generator/api/metrics                      | ^/generator/api/metrics$                          |
| /generator/api/metrics/query_range          | ^/generator/api/metrics/query_range$              |
| /ingester/ring                              | ^/ingester/ring$                                  |
| /memberlist                                 | ^/memberlist$                                     |
| /metrics-generator/ring                     | ^/metrics-generator/ring$                         |
| /querier/api/metrics/query_range            | ^/querier/api/metrics/query_range$                |
| /querier/api/metrics/summary                | ^/querier/api/metrics/summary$                    |
| /querier/api/search                         | ^/querier/api/search$                             |
| /querier/api/search/tag/{tagName}/values    | ^/querier/api/search/tag/(?P<v0>[^/]+)/values$    |
| /querier/api/search/tags                    | ^/querier/api/search/tags$                        |
| /querier/api/traces/{traceID}               | ^/querier/api/traces/(?P<v0>[^/]+)$               |
| /querier/api/v2/search/tag/{tagName}/values | ^/querier/api/v2/search/tag/(?P<v0>[^/]+)/values$ |
| /querier/api/v2/search/tags                 | ^/querier/api/v2/search/tags$                     |
| /querier/api/v2/traces/{traceID}            | ^/querier/api/v2/traces/(?P<v0>[^/]+)$            |
| /ready                                      | ^/ready$                                          |
| /shutdown                                   | ^/shutdown$                                       |
| /static/                                    | ^/static/                                         |
| /status                                     | ^/status$                                         |
| /status/overrides                           | ^/status/overrides$                               |
| /status/overrides/{tenant}                  | ^/status/overrides/(?P<v0>[^/]+)$                 |
| /status/usage-stats                         | ^/status/usage-stats$                             |
| /status/{endpoint}                          | ^/status/(?P<v0>[^/]+)$                           |
API documentation: https://grafana.com/docs/tempo/latest/api_docs/
Can I Trust the /status/endpoints or are the the otlp endpoints not listed here if it is configured correctly?
OTLP GRPC is on the port 4317 and OTLP HTTP on the port 4318 by default (and you are using default otlp config).
