Is there more information on billing? We are considering using the hosted solution but the “Metric Ton” description doesn’t mean a lot in a concrete way.
What counts as a datapoint in the context 18000 datapoints per minute? If you go over once, do you get charged for MetricTon. etc.
Not exactly useful. I was referring to the MetricTon that Grafana uses to measure and apply pricing to their cloud offering.
I’m not sure exactly how to quantify this and estimate expenses for our use case.
Does ~20+ servers refer to Grafana cloud’s servers? Does it refer to how many instances I have piping in metrics?
The point I’m trying to get across is that the pricing is ambiguous and I don’t want to commit to using this hosted solution without being able to estimate the costs with some amount of accuracy.
