Hi! I’m right now using grafana cloud free version for trial before buying the paid version. However, after using it for a month to understand the billing, I’m having confusion on total billable metrics.
This is my cardinality dashboard. As you guys can see the total series is only 1041
However, the total billable series is ± 22000. That’s really a lot. can anybody help me how does grafana cloud count the total billable series? it should be not this much.
lIs there any configuration that maybe I miss? I use grafana alloy to publish the data.
here is the configuration.
logging {
level = "debug"
format = "logfmt"
otelcol.receiver.otlp "default" {
// configures the default grpc endpoint "0.0.0.0:4317"
grpc { }
// configures the default http/protobuf endpoint "0.0.0.0:4318"
http { }
output {
metrics = [otelcol.processor.resourcedetection.default.input]
logs = [otelcol.processor.resourcedetection.default.input]
traces = [otelcol.processor.resourcedetection.default.input]
otelcol.processor.resourcedetection "default" {
detectors = ["env", "system"] // add "gcp", "ec2", "ecs", "elastic_beanstalk", "eks", "lambda", "azure", "aks", "consul", "heroku" if you want to use cloud resource detection
system {
hostname_sources = ["os"]
output {
metrics = [otelcol.processor.transform.drop_unneeded_resource_attributes.input]
logs = [otelcol.processor.transform.drop_unneeded_resource_attributes.input]
traces = [otelcol.processor.transform.drop_unneeded_resource_attributes.input]
otelcol.processor.transform "drop_unneeded_resource_attributes" {
// https://grafana.com/docs/alloy/latest/reference/components/otelcol.processor.transform/
error_mode = "ignore"
trace_statements {
context = "resource"
statements = [
"delete_key(attributes, \"k8s.pod.start_time\")",
"delete_key(attributes, \"os.description\")",
"delete_key(attributes, \"os.type\")",
"delete_key(attributes, \"process.command_args\")",
"delete_key(attributes, \"process.executable.path\")",
"delete_key(attributes, \"process.pid\")",
"delete_key(attributes, \"process.runtime.description\")",
"delete_key(attributes, \"process.runtime.name\")",
"delete_key(attributes, \"process.runtime.version\")",
metric_statements {
statements = [
log_statements {
statements = [
output {
metrics = [otelcol.processor.transform.add_resource_attributes_as_metric_attributes.input]
logs = [otelcol.processor.batch.default.input]
traces = [
otelcol.processor.batch.default.input,
otelcol.connector.host_info.default.input,
otelcol.connector.host_info "default" {
host_identifiers = ["host.name"]
output {
metrics = [otelcol.processor.batch.default.input]
otelcol.processor.transform "add_resource_attributes_as_metric_attributes" {
metric_statements {
context = "datapoint"
statements = [
"set(attributes[\"deployment.environment\"], resource.attributes[\"deployment.environment\"])",
"set(attributes[\"service.version\"], resource.attributes[\"service.version\"])",
"set(attributes[\"service.name\"], resource.attributes[\"service.name\"])",
output {
otelcol.processor.batch "default" {
timeout = "30s"
output {
metrics = [otelcol.exporter.otlphttp.grafana_cloud.input]
logs = [otelcol.exporter.otlphttp.grafana_cloud.input]
traces = [otelcol.exporter.otlphttp.grafana_cloud.input]
otelcol.exporter.otlphttp "grafana_cloud" {
client {
endpoint = "https://otlp-gateway-prod-ap-southeast-1.grafana.net/otlp"
auth = otelcol.auth.basic.grafana_cloud.handler
otelcol.auth.basic "grafana_cloud" {
username = "<FILTERED>"
password = "<FILTERED>"
