Is it possible to define general notificatin for whole dashboard in Grafana? Let’s say we have many graphs on dashboard with defined thresholds. Is it possible to send general notification in case of any threshold has been crossed?
To make it clear: Dashboard with graphs for severs of the same type. Each server has several licenses for some functionalities. Each license is depicted in separate graph. I don’t want to multiply notification definitions for each license. So it would be great if it would be possible to define notification once - which would point to the dashboard OR define notification template and reuse in every graph.
regards, Mike
