Grafana Enterprise License expired, I want to remove the banner saying license expired on my UI
Hello Team,
My customer was using Grafana enterprise version in his environment & the license expired 2 months ago, Now there is a banner saying "Grafana Enterprise License has expired " on the UI which is quite irritating to my customers & they want me to remove it. any idea how to do it by doing some configurations in grafana.ini .
Your customer was using licensed Grafana Enterprise and now it is still using unlicensed Grafana Enterprise. Solution is easy: renew a license or switch to OSS version.
You are right, these two are the options i had in mind, Can there be third making some config changes so that the banner gets removed, Or will it require change in code any idea… My last resort would be asking my customers to move to OSS as they wont renew the license .
Your only 2 options are
  1. Pay
  2. Go OSS
Other than that, code change etc, would be breaking the licensing agreement which is not legal
Yes i meant to say code change required so that can be done by Grafana support or not at all possible …so only two options for me
To my understand, OSS and Enterprise are essentially the same. You can comment out root_url and license_path from the grafana.ini file and restart it.
Hi, you can use this API Licensing HTTP API | Grafana documentation which removes the license stored in your Grafana database
