Dear team,
I use Grafana Enterprise 10.X on Windows.
Could you explain how to remove a license (file or env)?
As I know,
basically Grafana uses defaults.ini and other ini file that is defined ‘–config’ parameter.
for removing a license, Do I need to look ini files above?
If there is nothing regarding license options in above files,
I think <paths.data>/license.jwt file used as default value.
ref. Configure Grafana Enterprise | Grafana documentation
So, It needs removing license.jwt file and just do it ‘restart’?
