Activate Enterprise License not completed
    Enterprise (Free & unlicensed) v10.2.2 (161e3cac5075540918e3a39004f2364ad104d5bb)
    Ubuntu 22.04 , nginx
  • What happened?
    I try to active Enterprise lincense , But not success the System show error massage as below
    i need to activated Enterprise License on my Server Host
    http://52.77.219.33:3000/
Your license is for “http://52.77.219.33:3000/”, so make sure you are using this url, e.g. it is in your browser and it is in root_url option in the [server] section of the Grafana configuration file (if you are using reverse proxy, load balancer, …)
Hi , Jangaraj
Thanks you for resopnse. i try as you recommaned but gafana can not start
Plese help me to check / mistake some things wrong , more detail as files attached.
This is my Grafana.ini
So check Grafana logs to see what’s wrong. That’s generic recommendation: try to check always logs for more details
This is Log file instance Grafana Server
