Grafana cloud -
To add New Relic datasource -
Configure on Home > Connections > Data sources > grafana-newrelic-datasource-1 -
What happened?
Got error as below
Success adding New Relic datasource -
N/A -
No.
New Relic is enterprise plugin = you need valid enterprise license, but you have expired enterprise license. So this is error is correct: you don’t have valid license => you can’t use licensed plugin.
Hi @azlanazman
If you are a paying customer of Grafana Cloud then login to your Cloud account and can open directly a ticket from there:
Here is also a link to it:
Sure. Thanks, @usman.ahmad
