Grafana 7.5.8.
How do I tell if my enterprise license is installed?
Grafana 7.5.8.
Example:
Thanks @anon70503803
I get this when uploading my license file:
my custom.ini is
[server]
# Protocol (http, https, h2, socket)
protocol = http
# ??? - not sure how to specify both http and https
# The ip address to bind to, empty will bind to all interfaces
;http_addr =
# The http port to use
http_port = 8080
# The public facing domain name used to access grafana from a browser
domain = mesapp1
# Redirect to correct domain if host header does not match domain
# Prevents DNS rebinding attacks
;enforce_domain = false
# The full public facing url you use in browser, used for redirects and emails
# If you use reverse proxy and sub path specify full url (with sub path)
;root_url = %(protocol)s://%(domain)s:%(http_port)s/
Hi @jbenhabb
You should have extended support if you are paying for an enterprise license. Have you tried making a support ticket? Those folks are there to help you out full time, and they have more expereince with our Enterprise offerings.
If that’s not an option, let me know!
