Grafana 8.1.2 problem with Panel agenty-flowcharting-panel v0.9.1
I have problem with Grafana 8.1.2 since I upgraded this evening.
The problem only on agenty-flowcharting-panel v0.9.1 that not shown the image properly. Then I downgraded Grafana to 8.1.1 and the panel worked as expected.
When I upgraded to 8.1.2, I ran grafana-cli plugins update-all but no luck with the panel, still missing the image.
Regards,
Fadjar Tandabawana
Hi Fadjar,
I think this is a bug. I can load that plugin on 8.1.1 via a Docker Compose but not via the plugin admin. I think we should report it in the repo.
Good news, I got the plugin to load on 8.1.2 using this docker compose and the ENV config for loading the plugin:
version: "3"
services:
  grafana:
    image: grafana/grafana:8.1.2
    ports:
      - 3000:3000
    environment:
      GF_AUTH_ANONYMOUS_ENABLED: 1
      GF_AUTH_ANONYMOUS_ORG_ROLE: Admin
      GF_INSTALL_PLUGINS: agenty-flowcharting-panel
@fadjar340
You’ve probably noticed this but it seems that the issue is fixed on main :+1:
