Before i am using grafana 8.3.3. that show the image properly
I upgraded to grafana version 9.1.4.I have installed those plugins agenty-flowcharting-panel-0.9.0.zip,agenty-flowcharting-panel-1.0.0b-SNAPSHOT.zip,agenty-flowcharting-panel-1.0.0d.220606199-SNAPSHOT.zip in grafana version 9.1.4, that not shown the image properly. Could you please check this issue?
Thanks
Ron
did you enable download image in the panel option ?
Did you try to use your XML back in draw.io ? just to see if it’s working well
since you are displaying the image default error i think it’s working.
Otherwise you can try to use Draw.io icon built in only, i already had issue with downloaded image.
Hello @alexandrearmand ,community team,
I installed my grafana on rancher kubernetes. I could access it. But only have the issue break icon of images. i also tried to change to allow draw I in panel option. But it is same.
Could you show me. Whether we can download images. Kindly find my screenshot. i try to use my XML back in [draw.io]. it is same issue. show only in draw.io. But it is missing and break icon in dashboard.
dashboard is missing icon and break images:
configuration in panel:
i think the refresh is not dynamic can you use option allox draw io and save the board and refresh web page ?
Hello @alexandrearmand , @communiy team,
I have changed. it is same. rule lost also.everything change to default.
Thanks
Ron
you can also check directed graph with apache echart panel,
it’s new and kind of upgrade.
look at this presentation :
Hello @alexandrearmand ,@ community team,
I will try to check with them. But it is not relate to panel agenty-flowcharting-panel.
Thanks
Ron
Hi @sonrondniit,
I checked about this plugin and it seems to be a community plugin (which is not maintained by us).
Suggestion would be to report this by opening a new issue to their official GitHub page so that they can check (my gut feeling is that it seems like a bug).
I have created a grafana react equivalent for the same have a look Grafana 9.1.x problem with Panel agenty-flowcharting-panel
