Grafana Flowcharting plugin not working
I’m reposting this here because I didn’t get any response on server fault
I have a grafana server (6.3.5) and I’d like to add the Flowcharting plugin. I’ve followed the installation instructions in the official documentation and did as follow :
sudo grafana-cli plugins install agenty-flowcharting-panel
installing agenty-flowcharting-panel @ 0.9.1
from: https://grafana.com/api/plugins/agenty-flowcharting-panel/versions/0.9.1/download
into: /var/lib/grafana/plugins
✔ Installed agenty-flowcharting-panel successfully
Restart grafana after installing plugins . <service grafana-server restart>
sudo service grafana-server restart
I can see the plugin installed in the plugins list but when I create a new dashboard and add a flowchart panel, I can’t configure it. In the visualization tab there’s nothing and the panel appears invisible except for a little arrow to change the size.
I don’t see any error in the grafana log.
I think the plugins of FlowCharting 0.9.1 not backward compatible with Grafana version 6.
You need to upgrade the grafana to latest version 8.1.5, but you need to check all the old panel manually to see which one that broken. This is because the major changes of the Grafana.
Regards,
Fadjar Tandabawana
I have created a react based plugin for the same have a look GitHub - manojrammurthy/grafanaflowchart
Upgrade Grafana to version 7.x or later to ensure proper plugin compatibility.
Install an older version of the Flowcharting plugin compatible with Grafana 6.3.5.
Alternatively, use the Grafana Canvas visualization feature as a replacement.
Have created a react version for the same have a look at it GitHub - manojrammurthy/grafanaflowchart · GitHub
