I have installed grafana on Zabbix server and I’m using grafana dashboard.
I have installed plugins like Zabbix and some other plugins and I have no problem.
But to create a network map, I need to install the agenty flowcharting panel plugin.
I copied it to the var/lib/grafana/plugins path, but it does not appear in my plugins list.
I even tried to install the plugin online, but it still doesn’t show up in the list of plugins.
Flowcharting panel has been replaced by Canvas Panel. Therefore Flowcharting plugin no longer works with modern versions of Grafana because of angular support deprecation.
Thank you for your reply.
Is this plugin suitable for creating a network map such as the status of switches and storages?
Or is there a better way?
I use Zabbix and I use Grafana as a dashboard because it has attractive dashboards
Check this blog post for Canvas panel capabilities:
Also new Node Graph panel is available:
thanks
also checkout the following as an option
