Cannot use new Features & core Panels V8.2.3
i updated today to the new Version 8.2.3.
On the new Features Site from v8.0 i can see new Panels like the State Timeline, or the multiple Y-axes.
My update was successfully but i cannot use the new features. Also my Grafana looks not like in the Demo.
My one looks like my previous version v7.x (left vs. v8.2.2 right)
The new core Plugins show me the Error: Error Loading Plugin
Here’s my log file:
t=2021-11-04T15:56:41+0100 lvl=warn msg="falling back to legacy setting of 'min_interval_seconds'; please use the configuration option in the `unified_alerting` section if Grafana 8 alerts are enabled." logger=settings
t=2021-11-04T15:56:41+0100 lvl=info msg="Config loaded from" logger=settings file="C:\\Program Files\\GrafanaLabs\\grafana/conf/defaults.ini"
t=2021-11-04T15:56:41+0100 lvl=info msg="Config loaded from" logger=settings file="C:\\Program Files\\GrafanaLabs\\grafana\\conf\\custom.ini"
t=2021-11-04T15:56:41+0100 lvl=info msg="Path Home" logger=settings path="C:\\Program Files\\GrafanaLabs\\grafana"
t=2021-11-04T15:56:41+0100 lvl=info msg="Path Data" logger=settings path="C:\\Program Files\\GrafanaLabs\\grafana\\data"
t=2021-11-04T15:56:41+0100 lvl=info msg="Path Logs" logger=settings path="C:\\Program Files\\GrafanaLabs\\grafana\\data\\log"
t=2021-11-04T15:56:41+0100 lvl=info msg="Path Plugins" logger=settings path="C:\\Program Files\\GrafanaLabs\\grafana\\data\\plugins"
t=2021-11-04T15:56:41+0100 lvl=info msg="Path Provisioning" logger=settings path="C:\\Program Files\\GrafanaLabs\\grafana\\conf\\provisioning"
t=2021-11-04T15:56:41+0100 lvl=info msg="App mode production" logger=settings
t=2021-11-04T15:56:41+0100 lvl=info msg="Connecting to DB" logger=sqlstore dbtype=sqlite3
t=2021-11-04T15:56:41+0100 lvl=warn msg="SQLite database file has broader permissions than it should" logger=sqlstore path="C:\\Program Files\\GrafanaLabs\\grafana\\data\\grafana.db" mode=-rw-rw-rw- expected=-rw-r-----
t=2021-11-04T15:56:42+0100 lvl=info msg="Starting DB migrations" logger=migrator
t=2021-11-04T15:56:42+0100 lvl=info msg="migrations completed" logger=migrator performed=0 skipped=431 duration=1.967ms
t=2021-11-04T15:56:42+0100 lvl=info msg="Validated license token" logger=licensing appURL=http://grafana.staged-by-discourse.com/ source=disk status=NotFound
t=2021-11-04T15:56:42+0100 lvl=info msg="Starting plugin search" logger=plugins
t=2021-11-04T15:56:43+0100 lvl=warn msg="The following files were not included in the signature" logger=plugins plugin=input files=[LICENSE]
t=2021-11-04T15:56:43+0100 lvl=info msg="Registering plugin" logger=plugins id=input
t=2021-11-04T15:56:55+0100 lvl=info msg="Registering plugin" logger=plugins id=innius-video-panel
t=2021-11-04T15:56:55+0100 lvl=info msg="Registering plugin" logger=plugins id=marcusolsson-dynamictext-panel
t=2021-11-04T15:56:55+0100 lvl=info msg="Registering plugin" logger=plugins id=snuids-radar-panel
t=2021-11-04T15:56:55+0100 lvl=info msg="Registering plugin" logger=plugins id=yesoreyeram-boomtheme-panel
t=2021-11-04T15:56:55+0100 lvl=info msg="Registering plugin" logger=plugins id=bessler-pictureit-panel
t=2021-11-04T15:56:55+0100 lvl=info msg="Registering plugin" logger=plugins id=fatcloud-windrose-panel
t=2021-11-04T15:56:55+0100 lvl=info msg="Registering plugin" logger=plugins id=grafana-image-renderer
t=2021-11-04T15:56:55+0100 lvl=info msg="Registering plugin" logger=plugins id=grafana-piechart-panel
t=2021-11-04T15:56:55+0100 lvl=info msg="Registering plugin" logger=plugins id=grafana-polystat-panel
t=2021-11-04T15:56:55+0100 lvl=info msg="Registering plugin" logger=plugins id=larona-epict-panel
t=2021-11-04T15:56:55+0100 lvl=info msg="Registering plugin" logger=plugins id=natel-discrete-panel
t=2021-11-04T15:56:55+0100 lvl=info msg="Registering plugin" logger=plugins id=corpglory-progresslist-panel
t=2021-11-04T15:56:55+0100 lvl=info msg="Registering plugin" logger=plugins id=flant-statusmap-panel
t=2021-11-04T15:56:55+0100 lvl=info msg="Registering plugin" logger=plugins id=grafana-clock-panel
t=2021-11-04T15:56:55+0100 lvl=info msg="Registering plugin" logger=plugins id=grafana-worldmap-panel
t=2021-11-04T15:56:55+0100 lvl=info msg="Registering plugin" logger=plugins id=michaeldmoore-multistat-panel
t=2021-11-04T15:56:55+0100 lvl=info msg="Registering plugin" logger=plugins id=vonage-status-panel
t=2021-11-04T15:56:55+0100 lvl=info msg="Registering plugin" logger=plugins id=aceiot-svg-panel
t=2021-11-04T15:56:55+0100 lvl=info msg="Registering plugin" logger=plugins id=farski-blendstat-panel
t=2021-11-04T15:56:55+0100 lvl=info msg="Registering plugin" logger=plugins id=cloudspout-button-panel
t=2021-11-04T15:56:55+0100 lvl=info msg="Registering plugin" logger=plugins id=pierosavi-imageit-panel
t=2021-11-04T15:56:55+0100 lvl=info msg="Live Push Gateway initialization" logger=live.push_http
t=2021-11-04T15:56:56+0100 lvl=warn msg="Scheduling and sending of reports disabled, SMTP is not configured and enabled. Configure SMTP to enable." logger=report
t=2021-11-04T15:56:56+0100 lvl=info msg="HTTP Server Listen" logger=http.server address=[::]:3000 protocol=http subUrl= socket=
t=2021-11-04T15:57:06+0100 lvl=warn msg="Access to requested plugin file will be forbidden in upcoming Grafana versions as the file is not included in the plugin signature" logger=http.server file=img\\logo-small-background.svg
t=2021-11-04T15:57:06+0100 lvl=warn msg="Access to requested plugin file will be forbidden in upcoming Grafana versions as the file is not included in the plugin signature" logger=http.server file=img\\icn-blendstat-panel.svg
t=2021-11-04T15:57:06+0100 lvl=warn msg="Access to requested plugin file will be forbidden in upcoming Grafana versions as the file is not included in the plugin signature" logger=http.server file=img\\logo.svg
t=2021-11-04T15:57:06+0100 lvl=warn msg="Access to requested plugin file will be forbidden in upcoming Grafana versions as the file is not included in the plugin signature" logger=http.server file=img\\clock.svg
t=2021-11-04T15:57:06+0100 lvl=warn msg="Access to requested plugin file will be forbidden in upcoming Grafana versions as the file is not included in the plugin signature" logger=http.server file=img\\discrete_logo.svg
t=2021-11-04T15:57:06+0100 lvl=warn msg="Access to requested plugin file will be forbidden in upcoming Grafana versions as the file is not included in the plugin signature" logger=http.server file=img\\icon.png
t=2021-11-04T15:57:06+0100 lvl=warn msg="Access to requested plugin file will be forbidden in upcoming Grafana versions as the file is not included in the plugin signature" logger=http.server file=img\\imageit_logo.png
t=2021-11-04T15:57:06+0100 lvl=warn msg="Access to requested plugin file will be forbidden in upcoming Grafana versions as the file is not included in the plugin signature" logger=http.server file=img\\michaeldmoore-multistat-panel.svg
t=2021-11-04T15:57:06+0100 lvl=warn msg="Access to requested plugin file will be forbidden in upcoming Grafana versions as the file is not included in the plugin signature" logger=http.server file=img\\piechart_logo_small.svg
t=2021-11-04T15:57:06+0100 lvl=warn msg="Access to requested plugin file will be forbidden in upcoming Grafana versions as the file is not included in the plugin signature" logger=http.server file=assets\\logo.svg
t=2021-11-04T15:57:06+0100 lvl=warn msg="Access to requested plugin file will be forbidden in upcoming Grafana versions as the file is not included in the plugin signature" logger=http.server file=img\\icon_status_panel.svg
t=2021-11-04T15:57:06+0100 lvl=warn msg="Access to requested plugin file will be forbidden in upcoming Grafana versions as the file is not included in the plugin signature" logger=http.server file=src\\img\\radar_logo.jpg
t=2021-11-04T15:57:06+0100 lvl=warn msg="Access to requested plugin file will be forbidden in upcoming Grafana versions as the file is not included in the plugin signature" logger=http.server file=img\\pictureit_logo.png
t=2021-11-04T15:57:06+0100 lvl=warn msg="Access to requested plugin file will be forbidden in upcoming Grafana versions as the file is not included in the plugin signature" logger=http.server file=img\\polystat.svg
t=2021-11-04T15:57:06+0100 lvl=warn msg="Access to requested plugin file will be forbidden in upcoming Grafana versions as the file is not included in the plugin signature" logger=http.server file=img\\windrose_logo.svg
t=2021-11-04T15:57:06+0100 lvl=warn msg="Access to requested plugin file will be forbidden in upcoming Grafana versions as the file is not included in the plugin signature" logger=http.server file=images\\worldmap_logo.svg
t=2021-11-04T15:57:10+0100 lvl=info msg="Request Completed" logger=context userId=1 orgId=1 uname=admin method=GET path=/public/app/plugins/panel/barchart/module status=404 remote_addr=192.168.0.200 time_ms=9 size=58914 referer=http://192.168.0.25:3000/plugins/barchart/
t=2021-11-04T15:57:43+0100 lvl=info msg="Request Completed" logger=context userId=1 orgId=1 uname=admin method=GET path=/public/app/plugins/panel/histogram/module status=404 remote_addr=192.168.0.200 time_ms=9 size=58914 referer=http://192.168.0.25:3000/plugins/histogram/
t=2021-11-04T15:57:56+0100 lvl=info msg="Request Completed" logger=context userId=1 orgId=1 uname=admin method=GET path=/public/app/plugins/panel/state-timeline/module status=404 remote_addr=192.168.0.200 time_ms=9 size=58914 referer=http://192.168.0.25:3000/plugins/state-timeline/
Can anyone pls help me?
@sniicker
  • where are you running grafana?
  • how are you running grafana?
  • how did you upgrade?
Hi @anon70503803 sorry my late answer.
Iam running grafana on a win10 machine.
Its running as a service.
I tried both - the installer and to overwrite with the binary files.
Made a clean install - works now.
