Grafana version: 10.0.2
operating system: mac - ios and ubuntu -
Import my dashboard from json -
I imported the dashboard successfully -
What happened?
When I edit the panels I get the notification: Graph (old) - Angular panel plugin
The selected panel plugin is using deprecated plugin APIs. -
Find in the documentation instruction for how to migrate the panel plugin in the browser -
Did you follow any online instructions? If so, what is the URL?|
I didn’t find instruction to fix this issue
Hi - the Graph panel was replaced by the Timeseries panel around Grafana v8. This doc Time series | Grafana documentation provides the guidance:
Note: You can migrate from the old Graph visualization to the new Time series visualization. To migrate, open the panel and click the Migrate button in the side pane.
Hope this helps
Thanks it helped
