~ THANK YOU!! the grafana team
Grafana 10 version
step by step procedure to Migrate from angular based plug in to react based plug in grafana -
made some changes in grafana configuration file
Added as below
[dashboards]
auto_migrate_old_panels =true
- What happened?
But still we have warning in grafana dashboards as “panel requires angular,deprecated” - What did you expect to happen?
No change we see the warnings still as “panel requires angular,deprecated”
I will upload the configuration file over here
no
- Did you follow any online instructions? If so, what is the URL?
chatgpt
