v8.0.6 (68fe9e3431) -
configure alerts with new feature published with Grafana 8 -
Upgraded grafana version from 7.0 to Grafana 8 -
What happened?
Even after upgrade, i am not seeing new Alerting feature in Grafana 8 -
I should see new Alerting features in Grafana 8 as mentioned in demo “Into to unified alerting in Grafana” -
What configuration ? i didn’t get this -
No error -
Not sure if you saw, but you need to enable ngalert explicitly in the config: Configuration | Grafana Labs
Thanks @svetb, my configuration says this.
[feature_toggles]
enable features, separated by spaces
;enable =
will this configuration not allow all features ?
Not sure if you had a chance to check the docs I linked to.
It will allow no features - or at least no alpha features.
Try enable=ngalert. Also make sure you remove the ; at the start of the line, since that would comment it out.
Thanks @svetb , it worked.
Updated the configuration(grafana.ini) and it worked.
[feature_toggles]
enable= ngalert
