jo49
1
Hi all,
after updating to 12.2., my GEOMAP-panels are working wrong.
There are two problems:
- the colour of mareker are wrong at some marker (in the red square), at some not (the green ones for example). In the same panel.
- data links are shown five times instead of one
Any idea?
Thanks a lot
Regards
Jürgen
Welcome @jo49
I am not seeing this issue myself on 12.2. Can you clone that dashboard, then edit something simple like the title, save it and see what happens?
jo49
3
I did two things:
- copied the geomap-panel inside thew dashboard and change the name –> nothing happend, both panels worked wrong
- cloned the whole dahsboard and chneged some things –> nothing happened, the panel in the new dashboard works also wrong
Forgott soemthing to mention: the datasource is infinity and the data’s are out of a csv-file.
jo49
4
And it looks like, that for each coloum a datalink-pair is generated, instead of generating only one pair..
My csv has five columns and I get five pairs of datalinks …
How could I avoid this? ….
yep I get it as well, time to file a bug
But it does not happen with following plugin that was a fork from geomap
jo49
6
Ok, so I’ll check the “Orchestra Cities Map”
And the wrong colour of the marker: I fixed it with changing the “fill-opacity” to 1
