Geomap no markers showing up - but tooltip does
Using Grafana 9.1.4 and PostgreSql 12.12 database running on Ubuntu 20.04
Datapoint for my test is:
select 55.60225977918819 latitude, 12.479173970814054 longitude, 10 sz, ‘Site1’ site
This is a point just south of the Copenhagen-marker on the default base layer.
I expected a marker to show up at that point, but no matter what I have tried - it does not show up. Moving the mouse to the point makes the tooltip appear - so the point is acceptet by the GeoMap.
I have never used the GeoMap panel before, but I feel my options searching for new approaches has exhausted.
I have tried in Chrome and Egde with the same result.
Below is the dashboard’s JSON:
“annotations”: {
“list”: [
“builtIn”: 1,
“datasource”: {
“type”: “grafana”,
“uid”: “-- Grafana --”
“enable”: true,
“hide”: true,
“iconColor”: “rgba(0, 211, 255, 1)”,
“name”: “Annotations & Alerts”,
“target”: {
“limit”: 100,
“matchAny”: false,
“tags”: ,
“type”: “dashboard”
“type”: “dashboard”
“editable”: true,
“fiscalYearStartMonth”: 0,
“graphTooltip”: 0,
“id”: 193,
“links”: ,
“liveNow”: false,
“panels”: [
“datasource”: {
“type”: “postgres”,
“uid”: “EJANwmQMz”
“description”: “”,
“fieldConfig”: {
“defaults”: {
“color”: {
“mode”: “thresholds”
“custom”: {
“hideFrom”: {
“legend”: false,
“tooltip”: false,
“viz”: false
“mappings”: ,
“thresholds”: {
“mode”: “absolute”,
“steps”: [
“color”: “green”,
“value”: null
“color”: “red”,
“value”: 80
“overrides”:
“gridPos”: {
“h”: 20,
“w”: 20,
“x”: 0,
“y”: 0
“id”: 2,
“options”: {
“basemap”: {
“config”: {},
“name”: “Layer 0”,
“type”: “default”
“controls”: {
“mouseWheelZoom”: true,
“showAttribution”: true,
“showDebug”: false,
“showScale”: false,
“showZoom”: true
“layers”: [
“config”: {
“showLegend”: true,
“style”: {
“color”: {
“fixed”: “dark-green”
“opacity”: 0.4,
“rotation”: {
“fixed”: 0,
“max”: 360,
“min”: -360,
“mode”: “mod”
“size”: {
“field”: “sz”,
“fixed”: 5,
“max”: 15,
“min”: 2
“symbol”: {
“fixed”: “img/icons/marker/circle.svg”,
“mode”: “fixed”
“textConfig”: {
“fontSize”: 12,
“offsetX”: 0,
“offsetY”: 0,
“textAlign”: “center”,
“textBaseline”: “middle”
“filterData”: {
“id”: “byRefId”,
“options”: “A”
“location”: {
“latitude”: “latitude”,
“longitude”: “longitude”,
“mode”: “coords”
“name”: “Sites”,
“opacity”: 0,
“tooltip”: true,
“type”: “markers”
“tooltip”: {
“mode”: “details”
“view”: {
“id”: “coords”,
“lat”: 55,
“lon”: 8,
“zoom”: 6
“pluginVersion”: “9.1.4”,
“targets”: [
“datasource”: {
“type”: “postgres”,
“uid”: “EJANwmQMz”
“format”: “table”,
“group”: ,
“metricColumn”: “none”,
“rawQuery”: true,
“rawSql”: "select 55.60225977918819 latitude, 12.479173970814054 longitude, 10 sz, ‘Site1’ site ",
“refId”: “A”,
“select”: [
“params”: [
“value”
“type”: “column”
“timeColumn”: “time”,
“where”: [
“name”: “$__timeFilter”,
“params”: ,
“type”: “macro”
“title”: “GHS Sites”,
“transformations”: ,
“type”: “geomap”
“schemaVersion”: 37,
“style”: “dark”,
“tags”: ,
“templating”: {
“list”:
“time”: {
“from”: “now-6h”,
“to”: “now”
“timepicker”: {},
“timezone”: “”,
“title”: “TestGeoMap”,
“uid”: “npmtq-VVz”,
“version”: 13,
“weekStart”: “”
Welcome
Have you mapped those values to the data layer’s longitude latitude?
Yes and the fact, that the tooltip appears should indicate, that the point actually is on the map, but no markers. I have also made an actually table in postgres with the same static data shown here, but no change.
and the point is a solid color
Very odd indeed. Not sure what to recommend as it works for me, identical setup
@yosiasz wow - thank’s for trying it out. Are you using geomap 5.0.0 ?
:eyes:
That’s what I qas showing you in that image I posted
Not sure what version of geomap
@yosiasz I made the panel from scratch again and now the dot is showing up!? Just pasting the SQL made the dot show, but no luck getting the first dashboard running. I delete that one and will bear that in mind for another occation :face_with_raised_eyebrow:
Thank’s for getting me in another direction.
