HI. I’ve hit what seems to be a bug in Grafana (V10.0.2) Dashboard - Geomap and I need assistance if it is not a bug. I’m trying to do some value mapping after doing transformations and it doesn’t work. The mapped values don’t change when I select Geomap, but when I select Table the mapping is okay. Can someone assist or is this an open Geomap bug.
If I inspect my data and under "data options"I select “apply panel transformations”, the value mapping shows but doesn’t on the panel.
