Geomap multiple data sources not working
I’m trying to use the geomap panel with 2 queries. In the map layers, I have 2 layers of markers and I want to select a different data source for each of them (the 2 queries). They both show up and are clickable, but clicking on the second one does nothing. It always takes the results from the first query.
Any idea what may be causing this, or how to fix it?
Currently using Grafana 9.2.2, same issue on 9.2.0
.Same issue here on grafana 9.4
I did exactly the same thing without any problem.
Here with Grafana v9.4.7.
