Cannot choose data option for Geomap layers
Hello everyone!
What happened:
I am using a built-in Geomap plugin and trying to use different layers to visualize data from a few queries.
But, the problem is that I cannot choose the right data option.
I believe it’s related to the undefined properties in the dropdown list. And after some research, I came to the conclusion that it’s related to the unset query name. But, here is another problem I cannot set it either.
What you expected to happen:
I can set the query name and choose a data option for different map layers without any problems.
How to reproduce it (as minimally and precisely as possible):
  1. Install Cognite Data Fusion Plugin
  2. Create a new data source with public data
  3. Get any geospatial data and try to duplicate the query.
  4. Try to choose different data for different layers.
Environment:
  • Grafana version: 9.4.7
  • Docker image: grafana-oss
  • Data source type & version: Cognite Data Fusion
  • User OS & Browser: macOS Ventura 13.2.1
  • Grafana plugins: Cognite Data Fusion plugin, built-in Geomap panel
Others
Here is a link to related unresolved issue
Greetings,
Can you provide us public data url?
Which geomap is that?
hi @yosiasz. I am using this plugin that comes with Grafana
I can provide a link to dashboard config that I created with dummy data. But it clearly demonstrates discovered issue.
how to setup the following? still waiting for you to provide sample public url
You can find guide here
set things up but not sure but missing data for this section. your dashboard queries do not match mine
