I’m using Grafana with the Infinity data source to fetch city data in JSON format, which looks like this:
{“id”:1,“name”:“HYDERABAD”,“latitude”:17.09677,“longitude”:78.31115},
{“id”:2,“name”:“BANGLORE”,“latitude”:12.9716,“longitude”:77.5946},
{“id”:3,“name”:“PUNE”,“latitude”:18.5204,“longitude”:73.8567},
{“id”:4,“name”:“MUMBAI”,“latitude”:19.076,“longitude”:72.8777}
I’ve created a multi-selection dropdown variable using this data. My goal is to visualize only the selected cities on a GeoMap panel based on the user’s selection in the dropdown.
How can I configure the GeoMap panel to filter and display only the selected cities from the dropdown?
basically that dropdown variable should store the selected cities complete data and I need to use the value of that variable in geomap panel.
