How to Enables multiple values select data option in only one GEO map interface
Welcome
Can you expound onthis a bit more not sure I understand. Maybe even draw put what you want to see
I have created a geo map on grafana with multiple filters using PostgreSQL Query.
Now i want to add multi-value selection functionality in filters by which filtered data will be represented on a single geo map but it is generating multiple geo maps or ERROR based on input selected in filters.
So can you tell me a method by which filtered data only generate one geo map without any ERROR or multiple Geo maps?
Show us the query that uses the filter and vet your query using query inspector right above query
This Plant datasource query:-
And I use two types of filter variable queries in it:-
Hub_Code query:-
Plant query:-
I dont see query inspector
