Dear all,
I am ploting GPS tracker measurements on one Geomap.
I am using different queries for each tracker. Currently I am using it in a way, I have to disable/enable query to hide/reveal particular stream.
I would like to simply click on particular stream in the “legend” in the bottom left corner. Similar to traditional visualization in Grafana, shown bellow. In bellow example I can select which sources I want the see, with simple clicking in the bottom row.
