Grafana 10.3.3. Installed in Kubernetes cluster through kube-prometheus-stack helmchart v56.19.0. Upgraded Grafana from v9.3.8
- What are you trying to achieve?
The special General Folder is not visible under <grafana_url>/dashboards
What happened?
The special General Folder is not visible under <grafa_url>/dashboards -
I expect all default dashboards are grouped and located under General Folder -
No
- Did you follow any online instructions? If so, what is the URL?
Upgraded through helm chart
