How to rename the General folder name to other name in Folder structure?
Hello @pravin0058
Is this what you are looking for?
To edit the name of a folder:
- Click Dashboards in the primary menu.
- Navigate to the folder by selecting it in the list, or searching for it.
- Click the Edit title icon (pencil) in the header and update the name of the folder.
The new folder name is automatically saved.
Just upgrade to 10.2+
To make using folders easier and more consistent, there’s no longer a special General folder. Dashboards without a folder, or dashboards previously in the General folder, are now shown at the root level.
If I do manually whenever my pod is restarted it will not be available, so how to fix this in helm chart or grafana-config map?
