Hi all,
we do reorg of our dashboard in some folder that we created using k8s-sidecar-target-directory annotations
options:
annotations:
k8s-sidecar-target-directory: "/var/lib/grafana/dashboards/infrastructure"
But all the dashboard still present and duplicated also in general folder.
How can we remove dashboard to be showed in general folder and general folder itself?
Thanks
S
the general folder is special and behave differently from any other folder that you might create.
I don’t believe it can be deleted
Thanks Matt, so do you know how to avoid that dashboards being duplicated on both folders?
Hello, was this ever figured out? We also have a similar issue and don’t want to show the general folder. It doesn’t make sense to automatically create a folder with everything inside when we have the dashboards organized outside.
Hi, we finally found the solution for that problem
# Set SCProvider to false to solve the General folder issue.
**SCProvider: false**
