What happened?
What Grafana version and what operating system are you using? version 10.3
What are you trying to achieve? Installing Grafana
How are you trying to achieve it? using apt install
What happened? the grafana front shows version 6.7 whereas the installed version in 10.0.3
What did you expect to happen? th eGrafana GUI should also be on 10.0.3
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. No error
Did you follow any online instructions? If so, what is the URL? Install Grafana | Grafana documentation
I guess that’s just cache in the browser. Try full refresh (CTRL+F5) a few times, clear the browser cache, try private window, another browser,…
