I use Grafana 9.1 or 9.3.2
Ubuntu LTS 22.04 -
I want to upgrade to the latest version -
By sudo apt-get updates -
What happened?
It is error
It can run smoothly -
Hi @arrrshaa,
Welcome to the
community support forums !!
I was looking at the 1st screenshot. It seems your system is not updating correctly as the repositories might not be up to date (either due to an old cache, or needing to be refreshed again).
You can do basic troubleshooting by first disabling the grafana repository and then updating the system to see if that fixes the initial problem.
