Cannot upgrade to 10.3 from 9.3.2
    Grafana (Enterprise) 9.3.2 and Ubuntu 22.04
    Upgrade current version to most recent
  • What happened?
    Upgrade to most recent version
    No errors
    Followed instructions on Grafana site for upgrading - used apt-get method.
When an apt-get upgrade is run the server OS and other applications upgrade however Grafana does not - no errors. I initially thought I had found the issue due to the GPG key needing updating so followed instructions on Grafana site to do this - seems to have gone smoothly as no errors. However, running apt-get upgrade again says no updates.
I have 2 questions here:
  1. Does anyone have any idea what could be causing this - why does it not see the later versions and upgrade?
  2. If this is insurmountable can I create a new install of the latest version and move my existing configuration across to the new install?
Any assistance would be greatly appreciated
Cheers
Marc
Hi @judgedredd
By chance. do you also have a purchased support of Grafana Enterprise?
